HELP! JDM integra Type R 5lug wheel bearing
Old Sep 21, 2006 | 01:05 AM
JDMITRTURBO's Avatar
Default HELP! JDM integra Type R 5lug wheel bearing
I just put a (was told its CTR) 5lug on my 00 civic si and my Driver side wheel bearing is bad...From what I can tell the USDM Type R wheel bearing isn't going to work so were do I find the jdm wheel bearing?...
ALSO from what ive been reading I can use the 95-01 CRV axles right?...( I think one of mine might be bad)
What other car has a 36mm Wheel bearing that I can use?....
Any help would be great!...
Modified by JDMITRTURBO at 12:33 PM 9/22/2006
Old Sep 21, 2006 | 01:15 AM
walker111's Avatar
Default Re: HELP! JDM integra Type R 5lug wheel bearing (JDMITRTURBO)
How do you know the ITR bearing wont fit? 44300-S04-A02
You should be able to use any b-series axles. They should be regular 32mm....
Old Sep 21, 2006 | 01:16 AM
Default Re: HELP! JDM integra Type R 5lug wheel bearing (walker111)
JDM is 36mm...I know for sure I have 36mm axles in there...
Old Sep 21, 2006 | 01:24 AM
walker111's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMITRTURBO &raquo;</TD></TR><TR><TD CLASS="quote">JDM is 36mm...I know for sure I have 36mm axles in there...</TD></TR></TABLE>
I didnt know CTR came in 36mm??
Old Sep 21, 2006 | 01:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">
I didnt know CTR came in 36mm??</TD></TR></TABLE>
I dont know anything about CTR I just know JDM Type R axles are 36mm and the ones I have in there are 36mm....Thats why im here for help...
Old Sep 21, 2006 | 01:29 AM
walker111's Avatar
CRV wheel bearing
Old Sep 21, 2006 | 01:30 AM
walker111's Avatar
edited
Modified by walker111 at 5:57 AM 9/21/2006
Old Sep 21, 2006 | 01:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">to make the 32mm axle work you need a 36mm outer hub also CRV</TD></TR></TABLE>
I was told the CRV axle is a plug and play...You dont have to mod it at all?...
Old Sep 21, 2006 | 01:42 AM
walker111's Avatar
I was told the CRV axle is a plug and play...You dont have to mod it at all?...</TD></TR></TABLE>
That would make sense but I'm not 100% sure. I found that info searching and I cant find anything about what ur saying. Someone will chime in with the correct answer, you'll just have to wait until they all wake up!
Old Sep 21, 2006 | 01:46 AM
There was also Cut ABS lines on there that I took off...I don't think CTRs had ABS so that better supports that its a ITR set up...
Old Sep 21, 2006 | 01:48 AM
Reid's Avatar
Global Moderator
EK9 CTR's were available with ABS.
If it has 36mm hubs, it's from an ITR. EK9 CTR's use 32mm hubs.
Old Sep 21, 2006 | 01:50 AM
walker111's Avatar
Default Re: HELP! JDM integra Type R 5lug wheel bearing (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">EK9 CTR's were available with ABS.
If it has 36mm hubs, it's from an ITR. EK9 CTR's use 32mm hubs.</TD></TR></TABLE>
Joo know what he needs for axles?
Old Sep 21, 2006 | 01:52 AM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">Joo know what he needs for axles?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMITRTURBO &raquo;</TD></TR><TR><TD CLASS="quote">95-01 CRV axles</TD></TR></TABLE>
They share the same part number.
Old Sep 21, 2006 | 01:56 AM
Sounds like I need to some how find out what hub I have then...Im almost sure those axles are 36mm but I guess I could be wrong...I hope Im wrong because that would mean I could use a usdm type R wheel bearing right?...(32mm)
Old Sep 21, 2006 | 01:59 AM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMITRTURBO &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like I need to some how find out what hub I have then...Im almost sure those axles are 36mm but I guess I could be wrong...I hope Im wrong because that would mean I could use a usdm type R wheel bearing right?...(32mm)</TD></TR></TABLE>
LOL! What happened to knowing for sure that you have 36mm axles?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMITRTURBO &raquo;</TD></TR><TR><TD CLASS="quote">I know for sure I have 36mm axles in there...</TD></TR></TABLE>
If they are 32mm, then you can use the same wheel bearings as USDM ITR's.
walker111's Avatar
Yes, if its a 32 then u should be suing the part number I supplied in my first post.
Old Sep 21, 2006 | 02:04 AM
I had to put new axles in my gsr and I didn't have the socket to take off the nut (32mm) so I went down and bought one and its to small for the ones I have now...When we did the swap the ones he put on even looked bigger....
Old Sep 21, 2006 | 02:06 AM
walker111's Avatar
So if you bought a 32mm socket and it didnt fit.........joo got 36mm axles dood.
Old Sep 21, 2006 | 02:08 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">So if you bought a 32mm socket and it didnt fit.........joo got 36mm axles dood.</TD></TR></TABLE>
Well 1 5/16 but ya I just went out and its not close...lol...
Old Sep 21, 2006 | 09:39 AM
tONE.steR's Avatar
* B A N N E D *
Well 1 5/16 but ya I just went out and its not close...lol...</TD></TR></TABLE>
1 5/16 = 1.3125 Inches
1.3125 * 25.4 = 33.375 Millimeters
If the socket is slightly loose, it looks like you have 32mm axles.
Old Sep 21, 2006 | 10:15 AM
Default Re: HELP! JDM integra Type R 5lug wheel bearing (tONE.steR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tONE.steR &raquo;</TD></TR><TR><TD CLASS="quote">
If the socket is slightly loose, it looks like you have 32mm axles. </TD></TR></TABLE>
That 1 5/16 was for my old teg....That one wont even fit over the new one so I take it I have 36mm axles...
Old Sep 22, 2006 | 09:34 AM
Anyone?...
Old Sep 22, 2006 | 09:42 AM
Reid's Avatar
Global Moderator
CRV wheel bearings are what you're looking for.
Old Sep 22, 2006 | 09:45 AM
hayabusa160's Avatar
im pretty sure the ctr didnt come with 36mm splines...
you must have gotten the 98+ jdm itr
i have a ctr 5 lug swap and it was the regular spline axles.
Old Sep 22, 2006 | 10:24 AM
Default Re: HELP! JDM integra Type R 5lug wheel bearing (hayabusa160)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">CRV wheel bearings are what you're looking for. </TD></TR></TABLE>
Cool...Thanks man....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hayabusa160 &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure the ctr didnt come with 36mm splines...
Ive come too it ITR 5lug...
