TB and Manifold Bore but to wut specs
Old Sep 20, 2006 | 03:34 PM
kornerk12's Avatar
Default TB and Manifold Bore but to wut specs
On an h22a4 motor with only bolt ons... what would you bore the TB to ? Is it worth it in your opinion ?
Old Sep 20, 2006 | 03:36 PM
K-Spec's Avatar
Default Re: TB and Manifold Bore but to wut specs (kornerk12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kornerk12 &raquo;</TD></TR><TR><TD CLASS="quote">On an h22a4 motor with only bolt ons... what would you bore the TB to ? Is it worth it in your opinion ? </TD></TR></TABLE>
i would just get an aftermarket TB with a euro-r mani upgrade or you can just modify the stock and get rid of those secondaries. You can't really bore the stock TB to a size that'd be worth it.
Old Sep 20, 2006 | 08:25 PM
InvaderTrax's Avatar
Not true. You can bore it out to 64mm (up from 60). I had mine done by maxbore.com and I can feel a mild difference
Old Sep 20, 2006 | 09:00 PM
BlUAc's Avatar
Default Re: (InvaderTrax)
the stock bore is 62mm, or is the a4 different and my opnion what are your future plans n/a, stock with mods, boost it all depends
Old Sep 22, 2006 | 02:21 PM
K-Spec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax &raquo;</TD></TR><TR><TD CLASS="quote">Not true. You can bore it out to 64mm (up from 60). I had mine done by maxbore.com and I can feel a mild difference</TD></TR></TABLE>
was the increase worth the $150 for boring + time of removing and installing it?
I got an aftermarket TB that's 68mm for $172...installed, so it was worth it for me.
Old Sep 23, 2006 | 07:20 AM
Eddiebx's Avatar
Default Re: (BlUAc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlUAc &raquo;</TD></TR><TR><TD CLASS="quote">the stock bore is 62mm, or is the a4 different and my opnion what are your future plans n/a, stock with mods, boost it all depends</TD></TR></TABLE>
stock bore on the a1,a4 are both 60mm, and the type-s is 62mm i believe.
HotboxedTypeR
Jun 27, 2008 01:59 PM
porter
Jan 9, 2007 03:27 PM
yeegsr
Oct 11, 2004 11:47 PM
BolivianFuego
Dec 14, 2003 11:20 AM
TTWS6
Jul 1, 2003 08:48 AM
