NGK BkR6E-11 Spark Plug Gap, what should it be at?
Old Apr 30, 2002 | 03:31 PM
pelotudo's Avatar
Default NGK BkR6E-11 Spark Plug Gap, what should it be at?
I checked a couple places, and haven't found a single right answer. I have a B16a1 (Not original engine in my CRX), and I just got NGK BKR6E-11 Non-Platinum plugs. I want to check the gapping on them and make sure they're right. I've heard .052, .051, .033... Which is it?
jB
Old Apr 30, 2002 | 03:38 PM
Rocket's Avatar
Default Re: NGK BkR6E-11 Spark Plug Gap, what should it be at? (PeloTudo)
Anything over 0.044 on the stock ignition is too big.
I like 0.038, it will give you both good low and hi rpm performance.
[Modified by Rocket, 10:18 PM 5/1/2002]
Old May 1, 2002 | 04:39 AM
Ant's Avatar
Ant
New User
from the helms-1.3mm(.051in) for a b16
[Modified by b16antsi, 8:40 AM 5/1/2002]
Old May 1, 2002 | 10:14 AM
Rocket's Avatar
Default Re: NGK BkR6E-11 Spark Plug Gap, what should it be at? (b16antsi)
Is that for the platinum plugs? The gaps can be run slightly wider on plugs with thinner electrodes.
Old May 1, 2002 | 10:18 AM
PyroVTEC's Avatar
New User
Default Re: NGK BkR6E-11 Spark Plug Gap, what should it be at? (Rocket)
If you're running FI or nitrous, you'll want to drop that gap to no more than 0.035." All-motor, run stock gap.
Old May 1, 2002 | 01:04 PM
brcivic411's Avatar
Anything over 0.44 on the stock ignition is too big.
I like 0.38, it will give you both good low and hi rpm performance.
hate to be picky.. but i think you mean .044 or .038!!!
Old May 1, 2002 | 01:17 PM
Rocket's Avatar
Default Re: NGK BkR6E-11 Spark Plug Gap, what should it be at? (brcivic411)
Yeah your right. At 0.44 the spark would have to be a lightning bolt.
Old May 1, 2002 | 02:18 PM
Name's Avatar
Your actually not soppose to gap ngk they come gaped and stay that way usually.
Jcup315
Apr 18, 2005 06:08 PM
Aeka GSR
Dec 5, 2003 10:14 AM
Licensed2Spool
Apr 8, 2003 04:22 PM
JeepNintegraGSR
Oct 30, 2002 02:40 AM
mattmw88
Feb 22, 2002 07:54 AM
