1/2 machined head stud question
Old Sep 20, 2006 | 02:08 PM
beaneg6's Avatar
Default 1/2 machined head stud question
going different route... /thread
Modified by beaneg6 at 10:29 AM 9/21/2006
Old Sep 20, 2006 | 02:18 PM
Boner_Ben's Avatar
Isnt the point of goign to a larger headstud to make it less prone to blowing headgaskets? And is it really necessary?
Old Sep 20, 2006 | 02:30 PM
G2K's Avatar
G2K
Default Re: (Boner_Ben)
For those of us that run decent size turbos @ high boost levels, the 1/2" studs are great for keeping the head down. I've only seen a few cars actually lift the head off the block, and they were all running up in the 38-42psi range.
Old Sep 20, 2006 | 02:35 PM
beaneg6's Avatar
Default Re: (DooDoo Brown Racing)
i understand that its stonger but when you open up the hole on the headgasket is it more prone to blowing than one that is not opened up!
Old Sep 20, 2006 | 02:57 PM
Slow00si's Avatar
Default Re: (beaneg6)
when you drill out the headgasket as long as its a clean hole no it wont blow out easier it will be just like as if it wasnt drilled out just be real careful because ive seen people do it and kinda ripped the gasket up and had to start over.
You dont happen to have a part # for the headstuds do you i e-mailed somebody about it the other day but i guess their not going to respond.
Old Sep 20, 2006 | 03:13 PM
beaneg6's Avatar
Default Re: (Slow00si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow00si &raquo;</TD></TR><TR><TD CLASS="quote">when you drill out the headgasket as long as its a clean hole no it wont blow out easier it will be just like as if it wasnt drilled out just be real careful because ive seen people do it and kinda ripped the gasket up and had to start over.
You dont happen to have a part # for the headstuds do you i e-mailed somebody about it the other day but i guess their not going to respond. </TD></TR></TABLE>
i can get the part number, give me a few hours
Old Sep 20, 2006 | 04:25 PM
Slow00si's Avatar
that would be awesome man, thanks
Old Sep 20, 2006 | 09:09 PM
beaneg6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow00si &raquo;</TD></TR><TR><TD CLASS="quote">that would be awesome man, thanks</TD></TR></TABLE>
sorry it took me so long,
stud # 200-8534
nut # 300-8334
Old Sep 20, 2006 | 10:16 PM
c jackson's Avatar
threes
you also need a washer #
Old Sep 21, 2006 | 02:16 PM
Slow00si's Avatar
Default Re: (c jackson)
actually that # for the studs is the washers and the number for the nut is right so now i dont have a stud part #
aemciv
Jun 21, 2005 05:09 PM
phatrick2332
Apr 27, 2005 09:30 PM
sporkcrx
Apr 8, 2004 09:03 PM
2civichatchbs
Feb 12, 2004 06:31 AM
zerofighter777
Aug 10, 2002 07:12 AM
