ls/vtec power question
Old Sep 20, 2006 | 01:07 PM
imskatencrzy's Avatar
Default ls/vtec power question
ok so i have a b18b1 block, b16 head with a p28 ecu from a 93 civic si. i have been told that as long as it is p28 it will work fine for an ls vtec setup. i took it out for a spin and it idles fine and all that but for some reason im not feeling that much more power. any sugestions?
Old Sep 20, 2006 | 01:09 PM
ekb16's Avatar
if its a stock p28 then theres ur problem...ur running a SOHC Vtec ecu on a DOHC vtec motor...wut u need to do is chip ur ecu
Old Sep 20, 2006 | 01:19 PM
BlueDragon436's Avatar
Default Re: (ekb16)
Yeah this is true, the P28 will run just fine to get you from point A to point B, and will not mess up your engine. You will not get the performance that you should out of it, as stated above, you are running a SOHC ecu on a DOHC, and on top of that you will get some crappy gas milage.
Old Sep 20, 2006 | 01:26 PM
FaceTuned's Avatar
Default Re: (BlueDragon)
damn you guys are trippin that **** needs to get socketed and atleast a gsr basemap. p28 and p72 maps are very different ok do some searching
HondaVTEC1993
Engine Management and Tuning
19
Apr 26, 2018 09:02 PM
chris42192
Texas -OK -LA (Sales)
Feb 25, 2010 06:24 PM
showbowt
Mar 19, 2008 03:06 PM
Homer_Simpson
Sep 29, 2001 05:01 AM
