weird Chugging and pinging......... need some nice person to offer advice
Old Sep 20, 2006 | 12:34 PM
EF9SIRJeff's Avatar
Default weird Chugging and pinging......... need some nice person to offer advice
i have a 93 4 door i bought for a daily driver
it is a stock DX 1.5 d15
it has a Severe chugging and sputtering problem past 1/10 throttle
which gets worse the further you go up the rpms or the wider open the throttle is
i have checked fuel pressure
i also kinked the fuel return line and pressure spiked up to 65 psi indicating the fuel pump is still good
i have checked all spark plugs to make sure they are getting spark, and they are
checked the cap and rotor and they were also good
also put in a new fuel filter
and new spark plugs and plug wires
im baffled here what could be wrong
Old Sep 20, 2006 | 12:40 PM
philosofy1's Avatar
Default Re: weird Chugging and pinging......... need some nice person to offer advice (EF9SIRJeff)
best case scenario, check you air filter, gas. worst case scenario, it's the beginning of bad piston rings or blown head gasket, causing a low compression.
Old Sep 20, 2006 | 12:42 PM
EF9SIRJeff's Avatar
Default Re: weird Chugging and pinging......... need some nice person to offer advice (philosofy1)
the compression was as follows
4-110
3-140
2-140
1-150
Bump
Modified by EF9SIRJeff at 3:16 PM 9/20/2006
Old Sep 20, 2006 | 02:16 PM
EF9SIRJeff's Avatar
bump
Old Sep 20, 2006 | 02:50 PM
OBRJosh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9SIRJeff &raquo;</TD></TR><TR><TD CLASS="quote">the compression was as follows
4-110
3-140
2-140
1-150
Bump
Modified by EF9SIRJeff at 3:16 PM 9/20/2006</TD></TR></TABLE> 110 is really low, Also check your timing
Old Sep 20, 2006 | 04:08 PM
Archidictus's Avatar
Unceasing Measure
Default Re: weird Chugging and pinging......... need some nice person to offer advice (OBRJosh)
Check your TPS and MAP sensors.
bassamillion
Honda Civic (2001 - 2005)
Jun 20, 2018 05:55 AM
MyEfSi2Slow
Sep 28, 2008 04:35 PM
BUILTandBOOSTED
Jun 26, 2008 08:04 AM
redciviclx14
Jun 28, 2003 08:01 PM
gsrvx
Sep 5, 2002 06:27 PM
