Recent B16A swap, but rotates and won't start
Old Sep 20, 2006 | 12:16 PM
ogawa_jiei's Avatar
Default Recent B16A swap, but rotates and won't start
Edited
Old Sep 20, 2006 | 12:20 PM
philosofy1's Avatar
Default Re: Recent B16A swap, but rotates and won't start (ogawa_jiei)
2.5 year old gas, eewww. start with that, the gas is probably bad.
Old Sep 20, 2006 | 12:22 PM
ogawa_jiei's Avatar
Default Re: Recent B16A swap, but rotates and won't start (philosofy1)
Edited
Old Sep 20, 2006 | 12:24 PM
philosofy1's Avatar
is this a car that has just been sitting around? did you swap the motor or have done any tuning?
Old Sep 20, 2006 | 12:47 PM
ogawa_jiei's Avatar
Edited
Old Sep 20, 2006 | 01:38 PM
ogawa_jiei's Avatar
Edited
Old Sep 20, 2006 | 02:52 PM
OBRJosh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ogawa_jiei &raquo;</TD></TR><TR><TD CLASS="quote">Just drained out all the old gas and put new gas in. Same problem though. Rotates but won't start. Any other takers? Please help! Thanks!
J</TD></TR></TABLE> Check your ground wire that goes to the thermostat housing and the ground that goes to the tranny
Old Sep 20, 2006 | 03:22 PM
ogawa_jiei's Avatar
Default Re: Recent B16A swap, but rotates and won't start (OBRJosh)
Edited
Old Sep 20, 2006 | 03:43 PM
OBRJosh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ogawa_jiei &raquo;</TD></TR><TR><TD CLASS="quote">OBRJosh, thanks for your reply. I am pretty sure everything is grounded well enough. I'm not familiar with tranny ground though. I have a 6-point grounding kit going through the whole engine bay. </TD></TR></TABLE> The main ground from the chassy goes to the tranns, double triple check cause if you got fuel and spark then its a ground or maybe cap and rotor
Old Sep 20, 2006 | 04:01 PM
ogawa_jiei's Avatar
Edited
Old Sep 20, 2006 | 04:24 PM
XkjeldorX's Avatar
why didnt u use ur original wire harness and just add the wires u needed to? i think i hear somewhere the japanese harness are different. maybe thats why??
Old Sep 20, 2006 | 04:26 PM
ZacCarter's Avatar
Main relay?
Old Sep 20, 2006 | 04:40 PM
ogawa_jiei's Avatar
Default Re: (ZacCarter)
Edited
Old Sep 21, 2006 | 12:44 AM
imjustakid's Avatar
first off all put ur old wiring harness back on because that wiring harness is made for a right hand drive.check for spark. if no spark get a new dizzy model td-44u for an obd1 setup. once u get spark it should start right up.
Old Sep 21, 2006 | 04:13 AM
ogawa_jiei's Avatar
Default Re: (imjustakid)
Edited
Old Sep 21, 2006 | 05:06 AM
92redhatch's Avatar
can you here the fuel pump prime when you turn the key? If not then either your fuel pump or something is wrong with the main relay. Check all your fuses, under the dash and in the engine bay.
Old Sep 21, 2006 | 06:11 AM
ogawa_jiei's Avatar
Default Re: (92redhatch)
Edited
87shytwhip's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ogawa_jiei &raquo;</TD></TR><TR><TD CLASS="quote">I used the right hand harness, but I soldered and extended each wire to reach the opposite side. It was a ton of work, but I was meticulous and did each one, one by one. I'm gonna replace some parts in the distributor.</TD></TR></TABLE>
swithch the harness [there was no real reason to keep the jdm one on, im not gonna say you might have messed up wiring something but if something is loose you might have f'd your self by keeping the jdm one on].. make sure your running the right dizzy.. and triple check your grounds.. when i did both of my swaps.. [my tranny ground was on but jst not tighened all the way and i looked like an idiot checking everything else when all i had to do was tighen one 10mm bolt].. TORQUE them down all the way yo..
Old Sep 21, 2006 | 07:11 AM
ogawa_jiei's Avatar
Default Re: (87shytwhip)
Edited
Old Sep 21, 2006 | 07:30 AM
87shytwhip's Avatar
Default Re: (ogawa_jiei)
yes connect it to the body.... i dont know where else you would put it.. .. umm also.. if you werent aware their are 2 tranny grounds.. one that goes to the body and one that is part of the wiring harness it self.. the one by the tranny usually is around the area of the the starter.. and the other one should be connected usually right underneith the dizzy above the vss sensor, right under the dizzy.. next to umm i think it is a brown looking plug.. i forget what that sensor is..but its around that area..
the second one i was describing is the one i kept forgetting because it was the last thing on my mind once i got all my sensors pluged up and ready to go..
Old Sep 21, 2006 | 07:37 AM
ogawa_jiei's Avatar
Edited
Old Sep 21, 2006 | 07:46 AM
87shytwhip's Avatar
my prediction is that when you rewired the harness the second gound i was talkin about .. you missed the connection or it is a totally bad connection to begin with..
but does it crank..???
Old Sep 21, 2006 | 07:51 AM
ogawa_jiei's Avatar
Edited
Old Sep 21, 2006 | 12:16 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OBRJosh &raquo;</TD></TR><TR><TD CLASS="quote"> Check your ground wire that goes to the thermostat housing and the ground that goes to the tranny </TD></TR></TABLE>
ground wires have nothing to do with this. if his ground wires were bad the engine wouldn't even crank.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ogawa_jiei &raquo;</TD></TR><TR><TD CLASS="quote">Well, I will double check those grounds, but yah, the engine cranks good. Sounds like a healthy crank. Just won't go... There's no spark. I check for spark yesterday.</TD></TR></TABLE>
if i had to take a guess i would say check your wiring. since you had to extend wires i would double check all the wires going to the fuel injectors. why? you might ask. i too had used a jdm harness on my jdm motor and had to extend the fuel injector wires.
Old Sep 21, 2006 | 12:41 PM
instructor74's Avatar
Is anyone else reading his post he has fuel and it cranks and he HAS NO SPARK. it is time to let the ground problem go and start finding out why he has no spark. Have you Check to see if your coil is good? have you replaced the igniter yet. Grab a shop manual it has all the info on how to test these parts with a multi meter. My first guess with out testing is going to be a problem with the coil.
