Cruise control doesn't work
Old Sep 20, 2006 | 10:31 AM
jam36a's Avatar
Default Cruise control doesn't work
Replaced my switch on the dash and checked the fuses. WTF? I need it working since i drive 70 highway miles a day to and from work. Argggh, its killing me. Someone please help.
Old Sep 20, 2006 | 12:37 PM
jdeemseerx's Avatar
first check to see if your brake lights work, i know it sounds weird but if your brake switch is faulty your cruise control will not work. do you have an SRS light on by any chance? start with that bc there are so many things that factor into diagnosing a cruise problem
Old Sep 20, 2006 | 12:58 PM
Hex420's Avatar
Default Re: Cruise control doesn't work (jam36a)
First do a search, I posted a great fix for this a while back.
there is a good chance that it is the stopper on you break pedal or clutch. Check to make sure the little button on the back of the pedal is peing pressed. If not replace the ruber stoper, with a bolt or an oem stopper from honda.
01CRVLX
Honda CR-V & Element
Jul 1, 2014 09:29 AM
Sweetsystem
Aug 26, 2008 01:58 PM
baybeboi
May 9, 2003 05:50 AM
SleepinGSR
Jan 25, 2002 12:09 PM
