need help with rear tranny mount.
Old Sep 20, 2006 | 10:00 AM
itsjdmbradyo!'s Avatar
Default need help with rear tranny mount.
Ok i swapped a b16a3 out of a 94 del sol into my 95 civic. all of the mounts lined up perfectly but on the rear tranny mount i got the two top bolts in but the two lower bolts that go into the block wont line up for some reason. and if i take out one of the top bolts and get the lower ones to line up then the top one wont realign to go back in! so has anyone had this problem? i was informed that all my stock mounts should work.
Old Sep 20, 2006 | 10:02 AM
turbociviccoupe's Avatar
Default Re: need help with rear tranny mount. (itsJDMbradyo!)
you need one from a 94-01 integra
Old Sep 20, 2006 | 10:03 AM
Default Re: need help with rear tranny mount. (turbociviccoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociviccoupe &raquo;</TD></TR><TR><TD CLASS="quote">you need one from a 94-01 integra</TD></TR></TABLE>
the mount that is on the frame or a tranny mount that bolt to the block/frame?
Old Sep 20, 2006 | 10:05 AM
the T or L bracket right?
Old Sep 20, 2006 | 10:18 AM
yes the bracket that goes between the frame mount and the block mounts.
Old Sep 20, 2006 | 10:19 AM
94-01 integra
Old Sep 20, 2006 | 10:21 AM
alright thanks.
hatchyksp
21
Mar 3, 2009 03:04 PM
esean93
Oct 12, 2008 03:29 PM
projectpd
May 14, 2007 10:30 AM
hondaguyef
Northeast (Sales)
10
Nov 1, 2005 03:20 PM
TYPE_EG6
Jan 2, 2005 04:41 AM
