Weird Black dust only on bumper.
I've noticed since I got the car there is always black dust on the top part of my bumper (back). I always wash it off. I just waxed it and cleaned it.
Looks suppper shinny and now i am noticing the black dust is a huge layer after 40km of driving !!!
I know its 40Km I reset it after i cleaned it and changed the tranny fluid.
Could it be that i am running rich?
You could be running rich or you could be burning oil. It is accumulating really quickly though it sounds like, so check your oil often. If you don't have a catalytic converter, that will accelerate the amount of carbon accumulating if you are running rich. Check your oil daily , or after the car is warmed up stand behind it and have a friend hit the gas, if there is blue smoke... there is burned oil.
Thanks for the prompt reply. I knew something was wrong.
I just changed my oil (to castrol gtx 5-30w) and i just checked my oil level in my garage (pretty level) and its 1 level over !
Could that be it?
Modified by tilhasbb at 12:00 PM 9/20/2006
Could that be it?
he leaked a little oil and now its a little over level.
I am running Castrol GTX 5-30W. Have been running it for a while.
Only thing i've done is add a ShortRam intake (Ebay cheapo thingy) and changed my spark plugs to G-power NGK and Changed Tranny Fluid.
I never understood the entire 5W30 in Winter and 10W30 in Summer. Why?
I know 5W30 is thinner but isn't that better because it goes more every where to cool the engine?
its getting cooler here now (I am in Canada, Montreal) by next month I wont be surprized if we'll see snow
i have the same probleme. i changed the valve seals but that didnt help. its either pistons rings or some of my valve guides. im running a little rich aswell.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilhasbb »</TD></TR><TR><TD CLASS="quote">i just checked my oil level in my garage (pretty level) and its 1 level over !
Could that be it?</TD></TR></TABLE>
Yes. If you overfilled the oil sump, you are guaranteed to burn oil until the excess burns off or until you drain it out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">I never understood the entire 5W30 in Winter and 10W30 in Summer. Why?
its getting cooler here now (I am in Canada, Montreal) by next month I wont be surprized if we'll see snow </TD></TR></TABLE>
Since you're in Montreal, just stick with 5W-30 year round. 5W-30 multi-viscosity oil flows slightly easier than 10W-30 in cold temperatures, allowing the oil to circulate faster during startup. When the oil is warm, they both have the same viscosity (hence the 30).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the omen »</TD></TR><TR><TD CLASS="quote">u need new rings my friend </TD></TR></TABLE>
And exactly how do you think you have accurately diagnosed this as bad rings by simply reading about black dust on a rear bumper over the internet with no other details?
hahahahahaha..... i thought this thread was a joke
seriously though, overfilling your oil means you have to much oil in your crankcase. It has to go somewhere so it pushes harder on your seals, maybe causing leaks, and it can push past your rings too, causing you to burn oil, resulting in a carbon buildup throughout your whole exhaust and rear bumper. duh.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
had te exact same prob with my eg
ill post pics tonite
it got really bad
i checked oil swapped visc and it still dusted
i checked and was running a little rich adj and still smk
pulled my motor apart (4 a turbo build) and the rings were pretty much gone
just my 2 cents from personal exp
</TD></TR></TABLE>had te exact same prob with my eg
it got really bad
If I do a compression test would that show if my rings are gone?
99 Civic Ex (Canadian SI) is suppose to be 185 i think? +-10 per cyclinder?
Is there a way to clean the carbon buildup ??
Since you're in Montreal, just stick with 5W-30 year round. 5W-30 multi-viscosity oil flows slightly easier than 10W-30 in cold temperatures, allowing the oil to circulate faster during startup. When the oil is warm, they both have the same viscosity (hence the 30).</TD></TR></TABLE>
Up here, I don't know about the majority of you guys lving down there, but Honda recommends 5W20 year round.
b16_swap
21
Oct 23, 2010 06:14 AM
