Suspension Question
Old Sep 20, 2006 | 09:50 AM
A-Rogue's Avatar
Default Suspension Question
First of all, let me start off by saying that my teg is not an ITR, but I figured you guys would know this better than the guys in the regular integra forum. The ITR is my dream car, but being a student, is unattainable right now. I have a 98 gs that is as close to an ITR as Im going to get. (A little bit faster, lots of itr parts, but still not an ITR). Here's a parts list
Engine/Trans:
B20b bottom end(re-sleeved) balanced
JE pistons (84.5) 11.1 comp
B18b Port n Polished Head Milled 15thous
Crower 403's/springs/ret
Fluidyne radiator
GSR Trans with ITR LSD
ACT street clutch
lighted flywheel
Energy Suspension Engine mounts
ITR AEM Cold air intake
AEM Fuel Rail/Regulator
AEM Cam Gears
Comptech Stainless 4-2-1
ITR Exhaust
ITR TB
Skunk2 Intake manifold
hondata s200
Suspension:
ITR Strut Tower
Comptech Swaybar/Tiebar
ITR H&R sports
Koni yellows
Omni power camber kit
ITR brake conversion with gunmetal ITR rims
Putting down 180whp and 142 ftq
My question is.... I only have about 3 inches of ground clearance on right now. I am thinking on selling my springs and putting in stock ITR springs and shocks to get some more height, but still be able to have a nice performing suspension. Will I be anywhere close to the legendary handling of a true ITR, or is the rest of my setup just too different??
Thanks for any advice.
Andy
Old Sep 20, 2006 | 10:45 AM
My95SlvrBlt's Avatar
an adjustable sleeve, and custom rate spring of your choice with yellows will actually put your spring/damper combo above ITR if properly matched to the car.
Overall the car setup sounds fairly mild, but well matched, and with a good springrate, rear biased rates, and koni yellows, you should be one happy camper.
Old Sep 20, 2006 | 10:52 AM
A-Rogue's Avatar
Default Re: (My95SlvrBlt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by My95SlvrBlt &raquo;</TD></TR><TR><TD CLASS="quote">an adjustable sleeve, and custom rate spring of your choice with yellows will actually put your spring/damper combo above ITR if properly matched to the car.
Overall the car setup sounds fairly mild, but well matched, and with a good springrate, rear biased rates, and koni yellows, you should be one happy camper.</TD></TR></TABLE>
I'd be one happy camper if its was an R, but this is a close second
Thanks for the help.
Old Sep 20, 2006 | 03:02 PM
98 ITR's Avatar
Just keep in mind that there's alot more going on on an ITR with respect to the way it handles. The suspension is one part of it, but the extensive modifications on the ITR shell plays a large part. This is why if you get an RS or LS, or even a GSR, slap some ITR suspension on it, and swap in a B18C5, the ITR will still destroy it on the track. Lighter weight in the right places and stiffer pillars, are just of few of the chassis mods on a type R. There is a diagram floating around somewhere with all the diffrences between an ITR and normal integra.
OP: I'd be willing to bet that if you were to throw some koni yellows and GC coilovers on with some custom rate springs, you'd have a very nice handling car. Unfortunately, I'd still put my money on a stock Type R in a track situation. You'd have some serious work to do if you want your car to behave the same way an ITR does in the twisties. They don't call it "the greatest front wheel drive car ever" for nothing.
Old Sep 20, 2006 | 03:42 PM
Default Re: (98 ITR)
The ITR is the daddy of integras, no doubt.
I was referring to strictly the spring/damper combo. For an out of the box, off the showroom floor setup, ITR is probably above 70% of cars made.
the chassis is what, 15% stiffer? That can SOMEWHAT be made up, but street application, it doesnt matter much anyway, as you can only use so much of what the car can do.
Old Sep 20, 2006 | 04:02 PM
A-Rogue's Avatar
Thanks for the help guys. Seems the nice people hang out in the ITR forum, Ill remember that
Old Sep 20, 2006 | 04:21 PM
George Knighton's Avatar
H-T Order of Merit
Default Re: (A-Rogue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A-Rogue &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the help guys. Seems the nice people hang out in the ITR forum, Ill remember that </TD></TR></TABLE>
Don't get spoiled. I assure you it was a temporary weakness.
Old Sep 20, 2006 | 04:27 PM
crxgator's Avatar
here and the crx forum are the only two forums with mostly good people...
the regular integra and 92-00 civic are a bunch of *******...
Old Sep 20, 2006 | 04:38 PM
98 ITR's Avatar
Default Re: (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">Don't get spoiled. I assure you it was a temporary weakness.
LoL. Werd.
My95SlvrBlt: I totally agree with you when it comes to street applications ... doesn't really matter who handles better in the corners on the street.
Old Sep 20, 2006 | 04:47 PM
A-Rogue's Avatar
Here's a pic just to show you what I we're talking about here.
Told you guys I wanted an R. Is it obvious? LOL
Thanks again fella's. You've been a big help!!! I'd like to maybe try my hand at an autox race with a stock R and see how close I can keep it. And when I lose, we'll go over to the 1/4 and switch roles. LOL
In all seriousness though, for you guys, favourite part of the site
ramboPandA
Jul 29, 2014 11:01 AM
RRRRRRRR
Suspension & Brakes
Feb 1, 2007 11:57 PM
integral94
Jan 7, 2004 07:35 PM
