How do u find leak on vacuum line?
Old Apr 30, 2002 | 02:58 PM
evo's Avatar
evo
New User
Default How do u find leak on vacuum line?
Been spending a month live with rough idle, i started to figure it the problem, have swaped the ECAV, throttle body, fast idle, the problem still occur,
I going to inspect the vaccum hoses, can someone tell me how to tell if there's a leak on the hoses? Do you use gauge or feel by hand?
Thanks
Old Apr 30, 2002 | 05:49 PM
A20A1's Avatar
Default Re: How do u find leak on vacuum line? (evo)
Get a can of "Throttle body Cleaner" (gumout) make sure it has the red plastic hose that you can stick into the cap.
Spray the cleaner close to but not directly @ the vaccum lines... The vapor should get sucked into the vaccum line and then from there it goes into the Maniflod... then finally it goes to the cylinders gets burned and creates a richer mixture... this richer mixture raises the idle. So you should hear your engine RPM's raise a bit maybe only by 100 rpm or so... temporarily. don't spray the cleaner near short ram intake filters... cause it will hurt the filter but also you will get the higer RPM's since your richining the mixture by spraying it into the filter.
If you only have a few vaccum lines then just feel by hand... also you should feel all the vaccum lines for stiffness... that most likely means the vaccum line is dryed out and will crack eventually.
Old Apr 30, 2002 | 07:32 PM
rainforest's Avatar
Default Re: How do u find leak on vacuum line? (A20A1)
soapy water on the lines.
Old May 1, 2002 | 12:14 AM
evo's Avatar
evo
New User
Default Re: How do u find leak on vacuum line? (rainforest)
Thanks guy. I try it today
Old May 1, 2002 | 12:15 AM
Kamin's Avatar
carb cleaner.
Old May 1, 2002 | 01:25 AM
evo's Avatar
evo
New User
Default Re: How do u find leak on vacuum line? (KAMiN)
Is not the vaccum, **** what else can that be?
[Modified by evo, 1:35 PM 5/1/2002]
ge_ej1
Jan 29, 2008 05:09 PM
93formula
10
Aug 14, 2007 07:12 PM
Tiffany_94DOHC
10
Apr 8, 2006 12:47 AM
f22abuilder
Feb 7, 2006 09:29 AM
adamjenkins80
Apr 15, 2005 09:04 AM
