Should I use a restrictor on my -3 fed TE 67
Old Sep 20, 2006 | 04:43 AM
Danny_EJ's Avatar
Default Should I use a restrictor on my -3 fed TE 67
I have a sleeved 2.0 gsr with a TE 67 and -3 line coming from my golden eagle sandwich adapter.
Everyone I know with this turbo doesnt use a restrictor, the person I bought it from recommends that i use one.
I have an equal number of people saying YES and saying NO.
Help, I dont know what to do. Using stock oil pump
Old Sep 20, 2006 | 05:56 AM
nebulight's Avatar
Default Re: Should I use a restrictor on my -3 fed TE 67 (Danny_EJ)
It won't hurt anything to use a restrictor, so why chance it. Function7 makes a really nice one:
Old Sep 20, 2006 | 09:35 AM
Danny_EJ's Avatar
anyone else
Old Sep 20, 2006 | 10:02 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: (Danny_EJ)
it wont hurt it in any way so why chance it... run the restrictor
Old Sep 20, 2006 | 10:51 AM
Speed Infliction's Avatar
Default Re: Should I use a restrictor on my -3 fed TE 67 (nebulight)
I also have a function seven restricter.
Old Sep 21, 2006 | 08:28 AM
Function7's Avatar
We typically do not recommend running a restrictor in a -3AN line unless the engine oil pressures are extremely high (i.e. over 85 psi @5000 rpm) since the -3AN line is already restrictive at lower pressures.
-A
Old Sep 21, 2006 | 08:40 AM
raene's Avatar
Default Re: Should I use a restrictor on my -3 fed TE 67 (Function7)
I'm running a -3AN line and still getting some seepage from the bottom of the turbo and out the turbo inlet... not actively dripping, just a light filmy coating. Oil pressures seem to be in the 80 range at the top end even with a T off the turbo feed line for the oil pressure gauge.
How little flow is too little?
Old Sep 21, 2006 | 09:10 AM
TheShodan's Avatar
Moderator
I do not recommend using a restrictor for that -3AN line as well. Not on a journal bearing series like that. No sir.
Old Sep 21, 2006 | 09:13 AM
alpha's Avatar
Default Re: (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">I do not recommend using a restrictor for that -3AN line as well. Not on a journal bearing series like that. No sir.</TD></TR></TABLE>
I agree
Old Sep 21, 2006 | 09:14 AM
tony1's Avatar
Exactly, alot more damage can be done by not getting the turbo enough oil. The -3 line is fine w/o a restrictor on a journal bearing turbo. It's easy to stick a restrictor on it and say "look, no more oil in the compressor housing", when you don't know until it's to late that you're doing damage to the turbo.
Old Sep 21, 2006 | 09:31 AM
Boosted Chemist's Avatar
Default Re: (tony1)
I have -3an and my car was smoking, oil in the chargepipe and some dripping out the exhaust. I have a b16a with itr oil pump and when my oil guage was working i saw 95 psi of pressure. THe turbo only had 1500 miles on it and has a great deal of shaft play. My return is mint all downhill. Resently i installed a restrictor and the smoke has decreases drastically.
The only problem i see with a restrictor is the pressure will increase but the volume will decrease (PV/nRT=PV/nRT)
Old Sep 21, 2006 | 12:50 PM
hybrid_KJ's Avatar
Default Re: (Boosted Chemist)
The pressure inside the line will increase but not inside the turbo. The restrictor creates a pressure drop across itself. I also don't run restrictors on -3 stuff either.
nipcup101
Jan 11, 2008 05:00 PM
Speed Infliction
Jul 17, 2006 07:51 PM
Prelude91siT
Jan 19, 2004 06:24 AM
boosted_zc
Jul 13, 2003 09:02 PM
AGen2integra
Sep 1, 2002 04:43 PM
