ok i searched for hours and hours please help
Old Sep 20, 2006 | 12:27 AM
87ludasi's Avatar
Default ok i searched for hours and hours please help
ok there is fuel spark timing is right it turns over but wont start everything else works ....i know its getting fuel cause i can smell it the car did sit for about four months before i bought it cause i sold my 87 si any info apprechiated ..........i dont think its the main relay cause i smell fuel or could it be? my jeep is due for a bigger lift and a v8 so i need to drive the lude now
Old Sep 20, 2006 | 05:16 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: ok i searched for hours and hours please help (87ludasi)
if you think it might be the mail relay then replace that...and if it doesnt work then thats obviously not the problem...Give that a try. It wont hurt. Other than that...I have no clue if its getting spark and fuel.
Old Sep 20, 2006 | 10:04 AM
Silver Surfer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 87ludasi &raquo;</TD></TR><TR><TD CLASS="quote">ok i searched for hours and hours please help </TD></TR></TABLE>
these type of thread topics are why you search for hours and hours with no results
how is someone with the same problem going to find this in the future?
please make more descriptive titles
Old Sep 20, 2006 | 10:23 AM
PrecisionH23a's Avatar
Replace the spark plugs since they are probably fouled out and add some fresh gas.
Old Sep 20, 2006 | 04:04 PM
87ludasi's Avatar
Default Re: ok i searched for hours and hours please help (PrecisionH23a)
i replaced wires plugs and everything pulled the hed valves are fine the only thing wrong was the timing belt i fixed that and bought plugs wires etc
Old Sep 20, 2006 | 08:50 PM
99LudeDude's Avatar
are you sure the timing isn't off 180 degrees? Just a thought. Also, fresh gas.
Old Sep 21, 2006 | 07:05 AM
Speedra500's Avatar
Default Re: (99LudeDude)
i would double check to make sure timing is correct, dont bother with the main relay if you smell gas, it is working fine, make sure your plugs are not fouled because they probably are if you are smelling gas, also make sure your firing order is correct, and maybe also check to make sure the distributor isnt on 180 degrees off? I dont know if thats possible on those motors, but might be worth checking
ghostcivic
Jan 16, 2007 02:46 PM
94_vteckiller
Apr 12, 2006 05:19 PM
bigbacon2
Sep 17, 2005 03:41 PM
95civickid
11
Apr 5, 2005 05:52 PM
sleepin91teg
Jul 19, 2004 01:57 AM
