Boosting d16 w/ 155,000
depends, depends, depends... is the engine in good shape? How's the compression? Does it burn oil? Does it run like a ratbag? Keep in mind, d16's have weak internals, especially high mileage ones. I wouldn't boost an engine like that unless it was in really good shape! On the other hand, they're easy to find if you blow yours up!
It would be safe as long as the motor is in good condition and you supply good fuel and spark. Tuning will be key with that high mileage. I would personally think about a rebuild first.
Just make sure you understand: http://www.homemadeturbo.com and have lots a fuel or you can ad your engine to the blown motor section..
jdmkrazie
13
Oct 5, 2024 08:56 PM
firstgenrex
Nov 17, 2003 01:42 PM
