Fuel Filler Neck
Old Sep 19, 2006 | 04:28 PM
Clairvoyant's Avatar
Default Fuel Filler Neck
The fuel filler neck on my 1993 Civic seems to be leaking a bit when I have the tank full. I just noticed it recently. Anyways, it took a look at it, and it's rusted up some and so on. I sprayed a sealer over it, and haven't noticed problems since. However, I may still buy a new neck and put it on myself. Just wondering if any of you have had experience with changing the fuel filler neck and how easy it is. I can get to it easily by taking off the rear wheel, just don't know how hard it is to disconnect it from the fender, etc. Any info is very much appreciated!
Old Sep 19, 2006 | 07:39 PM
jdmcars.com's Avatar
Default Re: Fuel Filler Neck (Clairvoyant)
Actually, never done it on a Civic before, but on the average car, removal from the quater is normally easy, it is normally just held up with a screw or bolt. However, most of the ones that I have had to replace, I have had to also lower the tank to get it correctly installed, or in same cases drop the tank completely.
Old Sep 20, 2006 | 12:45 PM
I had a look at how it hooks up to the tank. There's a small rubber hose section that the pipe connects onto at the end of it that goes to the tank. So I believe nothing has to be done with the tank.
Old Sep 21, 2006 | 01:09 PM
Default Re: (Clairvoyant)
Anyone at all have input?
Old Sep 21, 2006 | 01:54 PM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Clairvoyant &raquo;</TD></TR><TR><TD CLASS="quote">Anyone at all have input?</TD></TR></TABLE>
You're clairvoyant. Shouldn't you know the answer already
Old Sep 21, 2006 | 03:43 PM
Default Re: (Archidictus)
Stop making stupid remarks please.
-NA-H22A
Jun 16, 2006 09:53 PM
90 Si Hatch
Feb 19, 2006 03:26 PM
alfee
Apr 14, 2005 12:40 PM
turbologist
Oct 7, 2003 06:00 PM
turbologist
Oct 4, 2003 11:02 PM
