Clock and radio don't work.Del sol..WTF?
Old Sep 19, 2006 | 04:12 PM
picasso1's Avatar
Default Clock and radio don't work.Del sol..WTF?
1994 Del sol Si , the clock does not work and the radio is never saves its settings. Although the radio does work but does not save settings. So i always have to put the code in my stock honda deck for it to work everytime.
I checked all the fuses, they seem good.
I really would like to know what you guys think.
Im pretty good with wiring,but this problem i can't detect for the life of me,any suggestions?
Old Sep 19, 2006 | 04:47 PM
IOwNaHoNdA's Avatar
Default Re: Clock and radio don't work.Del sol..WTF? (picasso1)
maybe your memory wire for the deck is not wired up...
Old Sep 19, 2006 | 04:51 PM
perseverance's Avatar
there's probably an inline fuse blown. find ur 12v constant/memory wire and run a 12v constant source from ur ignition. ur problem will be solved with both the clock and radio since they're on the same circuit.
Old Sep 19, 2006 | 05:55 PM
melsers's Avatar
did you check the "back-up" fuse under the hood?
Old Sep 19, 2006 | 06:11 PM
if the fuse was blown... the clock nor radio would work. now that i think of it,it could be a bad ground. get a dmm and do a continuity test. or come to orlando and i'll help ya out.
Old Sep 19, 2006 | 06:45 PM
mc's Avatar
mc
Default Re: Clock and radio don't work.Del sol..WTF? (perseverance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by melsers &raquo;</TD></TR><TR><TD CLASS="quote">did you check the "back-up" fuse under the hood?</TD></TR></TABLE>
Old Sep 19, 2006 | 07:05 PM
NJcoupe's Avatar
Default Re: Clock and radio don't work.Del sol..WTF? (melsers)
Thats most likely what it is.
Old Sep 19, 2006 | 10:50 PM
melsers's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perseverance &raquo;</TD></TR><TR><TD CLASS="quote">if the fuse was blown... the clock nor radio would work. now that i think of it,it could be a bad ground. get a dmm and do a continuity test. or come to orlando and i'll help ya out.</TD></TR></TABLE>
If the "radio" fuse was blown, nothing would work. The "back-up" fuse just keeps the memory
Old Sep 20, 2006 | 06:01 AM
Everyones Hero's Avatar
I had the same problem. I finally wired my radio to a constant & wired in a switch to turn it on & off.
My clock kept resetting to 12:00 (or is it 1:00?). For some reason it eventually fixed itself.
If you find out what it is make sure to post it up.
Old Sep 20, 2006 | 06:57 AM
ok... explanation of how a radio works. u need two wires for power..12v constant and 12v accessory. ur 12v constant holds memory. it wouldn't only turn on when u turn the car on. if the backup fuse was blown then ur constant wire would not work and ur radio wouldn't work. u need 2 12v sources and a ground for the radio to turn on. like i said... run a wire from a 12v source to ur 12v constant on the harness and you'll be good to go.
Old Sep 20, 2006 | 08:48 AM
bluescrews's Avatar
i'd say check on the Back-Up (7.5A) fuse in the engine bay fusebox. This is the culprit most of the time
Old Sep 20, 2006 | 11:22 AM
picasso1's Avatar
Memory wire is the white with blue stripe, i believe and no, that does not work....because i had to bypass it to make my kenwood work
picasso1's Avatar
All the fuses under the hood are good.
Kenneth.Honda94
Audio / Security / Video
Sep 16, 2014 10:04 AM
Stevegunit16
Dec 20, 2006 02:01 AM
lazyweasal4
Dec 12, 2006 04:06 PM
Arsenal
Sep 29, 2005 11:12 AM
integra*RS*
12
Oct 19, 2003 06:12 PM
