chucked the timing belt off............................................... ..........................
Fellas, I chucked the timing belt off my car today, d15b2, do the piston and valves interfere with each other? did I hurt the engine? I turned the crank and could not hear anything?
Thanks in advance
Thanks in advance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 211811518 »</TD></TR><TR><TD CLASS="quote">Fellas, I chucked the timing belt off my car today, d15b2, do the piston and valves interfere with each other? did I hurt the engine? I turned the crank and could not hear anything?
Thanks in advance
I'm going to have a moment of silence for your D15b2
Thanks in advance
</TD></TR></TABLE>I'm going to have a moment of silence for your D15b2
You can either reaplce the timing belt and crank it up to check, or take the motor apart.
Ive broke a timing belt before and everything was ok. Put a new belt on and was good to go(i got lucky). I say throw a new one on and see what happens
thanks for your help guys, I've got some oil leaks so I think I'll pull the engine and put a gasket kit into it, I'll lift the head then.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 211811518 »</TD></TR><TR><TD CLASS="quote">thanks for your help guys, I've got some oil leaks so I think I'll pull the engine and put a gasket kit into it, I'll lift the head then.</TD></TR></TABLE>
good thinkin
plan more proj while it is out (minime?)
of course replace water pump and tensioner too
good thinkin
Water pump and tensioner too. ok. I will build up the z6 i got from the guy I bought the car from this winter.I want to put some pistons and a cam in it, which ones should I use?
