d16y8 2 layer oem headgasket?
I keep hearing about an OEM d16y8 2-layer headgasket that is supposed to be 0.025" thick. I also thought that there is a 3-layer d16y8 HG that is the same thickness as the d16z6 HG (0.037") Does anyone know if this 2-layer HG actually exists, and is there a part number?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lemon_juice »</TD></TR><TR><TD CLASS="quote">the two layer d16y8 headgasket comes from removing the middle layer of the 3 layer gasket. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16dcoe45 »</TD></TR><TR><TD CLASS="quote">so there is no "factory" 2 layer gasket I am guessing....</TD></TR></TABLE>
NO there isn't but do not forget when you start playing around like that you also need to get a cam gear to dial in the timing
personally a safer way to go would be to change the pistons
I know--I have SRP pistons--I was just thinking about it as a way to alter the compression a bit depending on what fuel. I am at 12:1 right now and run only 100 octane Cam 2.
Stonecoldn69
Jun 18, 2012 11:42 AM
kranked91dx
Jan 31, 2004 06:32 AM
