code 7 on a pwo ecu???
Old Sep 19, 2006 | 11:09 AM
90crxdxb16's Avatar
Default code 7 on a pwo ecu???
hey i got my car in motor runs great but throws a code.. seemms to be code seven i do not have an integra book to tell me how to diagnose.. the blinks on the ecu if some one could help it'd be great..
Old Sep 19, 2006 | 11:45 AM
Loserkidwac's Avatar
Default Re: code 7 on a pwo ecu??? (90crxdxb16)
All honda ECU codes are the same code 7 is for the TPS sensor located on the back of the Throttle body...it is either unpluged, not with in spec(.45v at idle and 5v at WOT), or just a bad sensor
Old Sep 19, 2006 | 11:50 AM
90crxdxb16's Avatar
Default Re: code 7 on a pwo ecu??? (Loserkidwac)
ok swet and i check codes by turing igniton to on position the long solid red ligth is the inbetween corect?.. the seven wquick i see would be the code?
Old Sep 19, 2006 | 01:23 PM
90CrX_Si's Avatar
when u turn the ignition the light will beep so many times them stop. ya i have the same problem with my crx =P dang TPS
Old Sep 19, 2006 | 01:32 PM
90crxdxb16's Avatar
yea its weird it runs fine.. just the check engine ligth comes on..anyone know where i can get a roll pin to fit my b16 shift linkage.. the onld one i punshedout.. kinda get a lil rough lookin so i wnat a new one to put back in
Old Sep 20, 2006 | 11:05 AM
90crxdxb16's Avatar
ok i just tested the tps.. at idle it was 4.73v... wat do i do from here?
Old Sep 20, 2006 | 11:46 AM
88 rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90crxdxb16 &raquo;</TD></TR><TR><TD CLASS="quote">ok i just tested the tps.. at idle it was 4.73v... wat do i do from here?</TD></TR></TABLE>
Did you test the middle wire?
Old Sep 20, 2006 | 02:24 PM
90crxdxb16's Avatar
Default Re: code 7 on a pwo ecu??? (88 rex)
no how do i test the middle i seemd to only get a reading when they where on the outer two pins..
Old Sep 20, 2006 | 08:22 PM
I think you need to test the v between the red and green wires, you will need to leave the sensor pluged in too
scarney
Sep 9, 2012 02:37 PM
andyc_0652
Nov 18, 2010 06:54 PM
shabam
Oct 23, 2006 07:14 AM
SpoonFedEF7
Mar 13, 2003 07:32 AM
