f22 engine in integra
Old Sep 19, 2006 | 09:12 AM
KillerElfboy's Avatar
Default f22 engine in integra
will a f22a1 engine and transmission(1991 accord dx sedan) fit into a 91 integra GS sedan?
i didnt know whether to put this in the accord or integra forum
Old Sep 19, 2006 | 09:45 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: f22 engine in integra (KillerElfboy)
you probably could.
You could probably follow the steps to putting a H series into that gen Integra with slight changes in wiring. And probably even use or slightly modify the mounts used in that type of swap for your desired swap.
I would search for the H series into that gen in the Integra forum and see what was done to make it work and that. That should give you a good idea of whats involved. The reason I say to search for the H instead of F is because I'm guessing the H is going to be more popular and easier to find info on. I wouldn't think that an H swap into that Integra would be too different from an F swap into the same year.
Old Sep 19, 2006 | 11:55 AM
Default Re: f22 engine in integra (TouringAccord)
awesome, if i can get the engine in the transmissions should go right in too right?
Old Sep 19, 2006 | 02:22 PM
SuperSlow's Avatar
need mounts.
you will be disappointed until you boost it.
Old Sep 19, 2006 | 04:49 PM
H-T Order of Merit
well, with the right mounts the transmission should go in fine but I'm sure you'll need to do some cutting to get the shifter assembly and shifter cable installed.
Old Sep 19, 2006 | 06:52 PM
future62
Guest
Posts: n/a
Mounts and an H2B kit...not at all a bad idea as F blocks come a dime a dozen, and even if you go the all-motor route the torque will always be enough to satisfy you. I'd go with an F22A6, F22B DOHC or H23A to start though...
Old Sep 19, 2006 | 06:55 PM
BlUAc's Avatar
yes for the shifter cables he will need to move a hole down towards the dash more
Old Sep 19, 2006 | 07:32 PM
The G-Man's Avatar
Default Re: f22 engine in integra (SuperSlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow &raquo;</TD></TR><TR><TD CLASS="quote">need mounts.
you will be disappointed until you boost it.</TD></TR></TABLE>
Not really, it is a big torque upgrade from any stock teg motor. And when built F22 can outrun an H.
Old Sep 19, 2006 | 11:40 PM
SuperSlow's Avatar
Default Re: f22 engine in integra (The G-Man)
outrunning stock H is really not any feat of marvel... built d series will outrun stock f/b/h series in a civic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The G-Man &raquo;</TD></TR><TR><TD CLASS="quote">
Not really, it is a big torque upgrade from any stock teg motor. And when built F22 can outrun an H.</TD></TR></TABLE>
Old Sep 20, 2006 | 04:33 AM
H-T Order of Merit
Default Re: f22 engine in integra (future62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by future62 &raquo;</TD></TR><TR><TD CLASS="quote">Mounts and an H2B kit...</TD></TR></TABLE>
could also use the F series to D series adapter plate from Bisi.
Bisimoto Race Engineering - Adapter Plates
Old Sep 20, 2006 | 09:01 AM
philadd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">could also use the F series to D series adapter plate from Bisi.
Bisimoto Race Engineering - Adapter Plates</TD></TR></TABLE>
I would definitely use either this or the H2B kit. If you run the F series trans, you're going to have a lot of headaches with the axles every few months.
Old Sep 20, 2006 | 06:41 PM
Default Re: f22 engine in integra (philadd)
axles eh? i went to see the integra today and it was all chewed up inside (leather) if its that much mod to fit the f series and tranny in there i might as well get another accord. thanks for the info guys
Old Sep 20, 2006 | 07:56 PM
ExplicitSpeed360's Avatar
Banned.
http://www.ExplicitSpeedPerformance.net
90-93 DA Integra H22A motor mount kit will work with F22 90-93 engines I believe
$464 shipped US
Old Sep 21, 2006 | 05:27 PM
v4lu3s's Avatar
RTFM
you need to look at the trans and see if it has FIVE bosses for studs or THREE&gt;
if it has 3 you CANNOT use an h22 mount kit.
if it has 5 bosses then you are set.
juniorjc007
Feb 17, 2006 07:42 AM
FULL-REV
Nov 9, 2005 10:12 AM
N-tEgRitY
Oct 4, 2005 12:34 PM
slamdataccord
Jul 22, 2005 07:34 PM
xvietxkhmerxboix
Sep 12, 2003 06:02 PM
