Exhaust Fitment Question
Old Sep 18, 2006 | 11:09 PM
Yellow3TypeR's Avatar
Default Exhaust Fitment Question
What other Acura exhaust systems would fit a '00 ITR. I'm going back to stock and have come up missing my stock cat and B pipe. No one around has a ITR exhaust system so I'm looking to piece together something else.....any suggestions.
Old Sep 18, 2006 | 11:34 PM
Speed Infliction's Avatar
Default Re: Exhaust Fitment Question (Yellow3TypeR)
no other stock exhaust is like the ITR. it is one of the best free flowing stock exhausts on the market. the gsr would be the closest, but is a smaller exhaust in diameter. not sure if it connects to the cat either. somebody else needs to chime in and answer that.
Old Sep 19, 2006 | 06:02 AM
LunchboxZT's Avatar
Default Re: Exhaust Fitment Question (Speed Infliction)
I have heard that the RS*R Exmag is close in sound, and a lil better in flow and maintains the stock look - I have not confirmed this however.
Old Sep 19, 2006 | 06:33 AM
Default Re: Exhaust Fitment Question (LunchboxZT)
does the GSR bolt up to the block? I may have access to the GSR system from the manifold to the muffler, so the cat fitment wouldn't be a problem. The only issue I am concerned about would be the length.
Old Sep 19, 2006 | 07:13 AM
Padawan's Avatar
Darth ModerVader
A '00-'01 GS-R or a '94+ LS system will bolt right up.
Old Sep 19, 2006 | 07:20 AM
Padawan's Avatar
Darth ModerVader
If you have a complete GS-R system from the manifold all the way back, that will also fit, regardless of the year. The only issue you might run into is the lack of a secondary O2 sensor bung in the cat, if the system is from an OBD-1 car.
Old Sep 19, 2006 | 08:54 AM
cltitus's Avatar
http://www.barancoacuraparts.c...ch=no
buy it new
Old Sep 19, 2006 | 09:45 AM
Default Re: Exhaust Fitment Question (cltitus)
yea b/c a new cat is only about $600.
Old Sep 19, 2006 | 10:51 AM
what about a stock exhaust manifold and a stock axle back - do any after market cats bolt right up to that???
Old Sep 19, 2006 | 10:57 AM
walker111's Avatar
I think he was talking about the muffler and b-pipe. Search high flow cat and you should be able to find some that fit.
Old Sep 19, 2006 | 11:16 AM
uNF$@#!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yellow3TypeR &raquo;</TD></TR><TR><TD CLASS="quote">does the GSR bolt up to the block? I may have access to the GSR system from the manifold to the muffler, so the cat fitment wouldn't be a problem. The only issue I am concerned about would be the length.</TD></TR></TABLE>
I hope you arent putting things back to "stock" to pawn the car to a misled individual.... but a LS bpipe and cat should work fine....
Old Sep 19, 2006 | 11:44 AM
Default Re: Exhaust Fitment Question (uNF$@#!)
nope, my car is paid off and I'm driving it until it blows up, again.
Old Sep 19, 2006 | 11:46 AM
walker111's Avatar
Then why put a shitty ls/gsr exhaust on it. There are a few aftermarket exhausts that sound close to stock.
Old Sep 19, 2006 | 02:39 PM
Default Re: Exhaust Fitment Question (walker111)
b/c right now it's on blocks - thought I had all my stock parts but have some up a few short, guess I didn't get em back when I changed em out. So I was scrambling for a quick fix. It was just a temporary solution.
Guyson
Oct 4, 2006 08:30 PM
Leithen
Jul 16, 2005 10:00 PM
mkiv98
Jan 23, 2005 05:19 PM
96_GsR_BlownEngine
Jul 22, 2004 08:11 PM
Grandprix
Jan 29, 2004 05:34 PM
