auto 2 man ecu question
will any ecu from a 88-91 civic manual trans work when comverting from an auto 90 crx dx to a manual trans? i know the ecu is not required, but recommended. thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsxr1k05 »</TD></TR><TR><TD CLASS="quote">will any ecu from a 88-91 civic manual trans work when comverting from an auto 90 crx dx to a manual trans? i know the ecu is not required, but recommended. thanks.
No, you will need a dx unless you are converting it to mpfi. then you can use an si pm6 ecu
