running wire for guages through firewall
Old Sep 18, 2006 | 08:42 PM
chadawesome's Avatar
Default running wire for guages through firewall
I have a 93 civic ex/si coupe, where can I run the wire/vacuum line for my guages through the firewall I can't find any holes & where can I hook up my guages to ign/12v, ground, and lighting sources?
Old Sep 18, 2006 | 09:10 PM
nighttrain33's Avatar
Default Re: running wire for guages through firewall (chadawesome)
All of mine are run in the driver's side just behind the tower for the shock. The very upper right-hand side (if you are looking at the front of the car toward the back). If it weren't raining, I would go outside and look because there is other major wiring that goes through the same grommet.
-Shane
Old Sep 18, 2006 | 10:01 PM
BlueIntegraBoy's Avatar
Behind the driver side shock tower near the clutch master cylinder. It runs through the firewall to underneath the dash.
Old Sep 18, 2006 | 10:22 PM
Default Re: running wire for guages through firewall (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Behind the driver side shock tower near the clutch master cylinder. It runs through the firewall to underneath the dash.</TD></TR></TABLE>
That's the one I was thinking of
-Shane
1sickHonda
Appearance Build Threads
Jun 25, 2008 01:01 PM
rollercosta123
Aug 16, 2006 12:30 PM
underdogdx
Jan 8, 2005 07:25 PM
OBDII Integra
Oct 20, 2004 11:47 AM
HondaMang
Jan 13, 2004 06:58 PM
