Help my friend and I diagnose!
Old Sep 18, 2006 | 08:02 PM
beak's Avatar
Default Help my friend and I diagnose!
car is a EM1 with LS/VTEC, fully built and turbo.
Car was running fine, no problems. Parked the car at home, turned it off, and the next day my friend tried to start it and it wouldn't start.
We tried a new ECU, new hondata, new dizzy. The car does not get spark still.
Anyone have any idea as to what we can try next?
Thanks in advance!!!
Old Sep 18, 2006 | 09:40 PM
EGwhat!!!'s Avatar
Default Re: Help my friend and I diagnose! (beak)
battery?? may sound stupid but check
Old Sep 20, 2006 | 04:02 PM
beak's Avatar
Default Re: Help my friend and I diagnose! (EGwhat!!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGwhat!!! &raquo;</TD></TR><TR><TD CLASS="quote">battery?? may sound stupid but check</TD></TR></TABLE>
No, I mean it does crank over.... just gets no spark....
Anyone?
Old Sep 20, 2006 | 04:05 PM
Luserkid's Avatar
Are you getting fuel? have you tried the main relay?
Old Sep 20, 2006 | 04:06 PM
knockout's Avatar
Default Re: Help my friend and I diagnose! (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Are you getting fuel? have you tried the main relay? </TD></TR></TABLE>
Old Sep 20, 2006 | 04:07 PM
beak's Avatar
Yeah, it has fuel....
Old Sep 20, 2006 | 04:21 PM
XkjeldorX's Avatar
Default Re: (beak)
check the ignitor inside the distributor. borrow one of ur friend dizzy and slap it on
Old Sep 20, 2006 | 04:37 PM
Luserkid's Avatar
Default Re: (XkjeldorX)
What does it do while its turning over? any pops or anything? How did you check spark, also try new plugs and wires.
Old Sep 20, 2006 | 05:42 PM
beak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XkjeldorX &raquo;</TD></TR><TR><TD CLASS="quote">check the ignitor inside the distributor. borrow one of ur friend dizzy and slap it on </TD></TR></TABLE>
We have a whole new dizzy :/
Old Sep 20, 2006 | 05:43 PM
beak's Avatar
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">What does it do while its turning over? any pops or anything? How did you check spark, also try new plugs and wires. </TD></TR></TABLE>
Nothing... just turns and turns and turns, and never catches.
We checked spark by holding a plug to the valve cover while cranking.
Also new plugs and wires... still no go
What else can we check?
Old Sep 20, 2006 | 07:26 PM
EKlscoupe_98's Avatar
did you check the ecm fuse
Old Sep 20, 2006 | 08:37 PM
Luserkid's Avatar
Default Re: Help my friend and I diagnose! (EKlscoupe_98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKlscoupe_98 &raquo;</TD></TR><TR><TD CLASS="quote">did you check the ecm fuse </TD></TR></TABLE>
Check that one and every other damn fuse you have.
Old Sep 20, 2006 | 08:42 PM
jdeemseerx's Avatar
timing belt snapped?
Old Sep 20, 2006 | 10:45 PM
japan4racing's Avatar
coil..check it
also do you have a msd set-up on the car?
if so you can:
remove the coil wire from the dizzy cap and set it about a 1/2" from a good ground (painted metal will not be best at all. use bare metal if possible or even a ground wire for the motor)
disconnect your white wire or cut it. turn the ign to the on position
tap the white wire to groud and you will know for sure if the ign box is working correctly.
if there is no spark when you do this:
swap your coil for another..if you have spark now your coil is the culprit
if still no spark after you swap coils check for 12v at the red wire coming from the msd box. make sure it is hooked up to a good 12v source.
if the wiring and all is good and you have no 12v on the red then you need to replace the msd box.
**** like this happens. electronic devices go bad with out warning sometimes..its just the nature of the beast. good luck with troubleshooting and update us when you find the problem.
Old Sep 23, 2006 | 01:40 PM
beak's Avatar
We checked all the fuses... arg!! I'll check them again?
Old Sep 23, 2006 | 01:41 PM
beak's Avatar
Default Re: (jdeemseerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdeemseerx &raquo;</TD></TR><TR><TD CLASS="quote">timing belt snapped?</TD></TR></TABLE>
don't say that!
nah, timing belt looks good
Old Sep 23, 2006 | 01:46 PM
beak's Avatar
Default Re: (japan4racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japan4racing &raquo;</TD></TR><TR><TD CLASS="quote">coil..check it
if so you can:
**** like this happens. electronic devices go bad with out warning sometimes..its just the nature of the beast. good luck with troubleshooting and update us when you find the problem.</TD></TR></TABLE>
Tried that... new coil and everything... even new dizzy... still no spark... can it be the crank angle sensor?? I wish it was easier to reach!
Old Sep 24, 2006 | 08:40 AM
jdeemseerx's Avatar
im guessing theres no codes eh?
Old Sep 24, 2006 | 09:24 AM
beak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdeemseerx &raquo;</TD></TR><TR><TD CLASS="quote">im guessing theres no codes eh?</TD></TR></TABLE>
No codes That would make this too easy!
Old Sep 24, 2006 | 11:18 AM
sauceja's Avatar
Default Re: (beak)
Check all your grounding points on the engine. If it is not getting a good ground it may cause your problem.
Usually though your starter wouldn't kick if it wasn't grounded good but you may not be getting strong enough spark power from lack of good ground.
BG97hx
Apr 6, 2008 09:22 AM
eltigre
23
Jun 7, 2006 12:16 PM
i_see_red
Jan 7, 2006 11:39 AM
Superhatch
10
Apr 17, 2004 12:05 PM
SpoolinEK
Dec 10, 2003 02:28 PM
