LS swap help
i need to know if i have to change throttle cables from the acura into the civic, and what about my alt wires? do i need to use my alt. out of my coupe?
the motor is a b18b1 into a 96 ex coupe that had d16y8
Modified by 96whitecoupe at 8:14 PM 9/20/2006
rear mount you can use your stock one but youll need a 99 si bracket cause the ls one is to long i belive. and pass. mount you can use your stock also im pretty sure. correct me if im wrong.
you need the rear T bracket i belive from a si
the driverside si bracket.
http://www.phear7imports.net/trey/6gen/
^ go there to double check ..
this helped me alot.
http://www.ff-squad.com/tech/w...8.jpg
wiring help ^
just PM me if you have any problems with wiring
( unless you didnt get the same obd gen as your car then i wont be able to help.. )
and your looking at the upwards of 135 for the brackets direct from honda.
so check your local junkyards ( i doutb you'll find it but its wortha shot..)
wiring help ^
well the motor is in.but my alt plug is diffrent do i have to use my altenator i know i have to use my distributor off my y8 can some 1 plz help me with all the wires i will not need to hook up and what i will? and what i have to change around. its a b18b1 going into a 96 ex coupe that had a d16y8 in it. thanks in advance
e-rob
Jun 22, 2009 07:12 PM
brasilstreet
Feb 28, 2004 07:48 AM
