B16b vtec hesitation
Old Sep 18, 2006 | 02:07 PM
B16b-EJ8's Avatar
Default B16b vtec hesitation
Hey guys...i have an off and on issue with a very slight hesitation in 3rd gear after vtec engages. once my b16b hits vtec in third gear it hesitates...almost seems like its bogging for like 2 or 3 seconds. Any ideas
Old Sep 18, 2006 | 02:14 PM
B16b-EJ8's Avatar
ttt
Old Sep 18, 2006 | 02:21 PM
B16b-EJ8's Avatar
Nevermind...search started working for me. I have plenty to read through...lock and delete post please.
EDIT: Went through archives...nothing with similar symptoms. Anyone have any ideas
Modified by B16b-EJ8 at 4:07 PM 9/18/2006
Old Sep 20, 2006 | 12:57 AM
ej1vtec's Avatar
Default Re: (B16b-EJ8)
i have almost the same problem. bogs when i quick shift to third. bogs for 2 seconds and catches itself.
Old Sep 20, 2006 | 10:17 AM
B16b-EJ8's Avatar
Default Re: (Quick_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quick_hatch &raquo;</TD></TR><TR><TD CLASS="quote">i have almost the same problem. bogs when i quick shift to third. bogs for 2 seconds and catches itself.</TD></TR></TABLE>
Thats exactly it. Still no clue why though
Old Sep 20, 2006 | 10:19 AM
turbociviccoupe's Avatar
what ecu?
Old Sep 20, 2006 | 11:29 AM
B16b-EJ8's Avatar
Default Re: (turbociviccoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociviccoupe &raquo;</TD></TR><TR><TD CLASS="quote">what ecu?</TD></TR></TABLE>
Stock PCT CTR ECU
Old Sep 20, 2006 | 11:32 AM
philosofy1's Avatar
have you tried a tune up? you know the regular, plugs, wires, fuel filter, etc.
Old Sep 20, 2006 | 12:27 PM
Stoich EG2's Avatar
Default Re: (philosofy1)
clutch not catching?
Old Sep 20, 2006 | 01:11 PM
B16b-EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">have you tried a tune up? you know the regular, plugs, wires, fuel filter, etc.</TD></TR></TABLE>
Did all that with the swap...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ADVAN EG2 &raquo;</TD></TR><TR><TD CLASS="quote">clutch not catching?</TD></TR></TABLE>
clutch is fine...
Old Sep 20, 2006 | 01:24 PM
FaceTuned's Avatar
what about the vss does your odometer act wierd like jumpy. i had that prob car hit vtec turned off and was slow but changed it and it worked perfect have not had a problem yet
Old Sep 20, 2006 | 01:25 PM
ej1vtec's Avatar
you replaced the FUEL filter too?
Old Sep 20, 2006 | 01:29 PM
B16b-EJ8's Avatar
Default Re: (jdmhatchness)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhatchness &raquo;</TD></TR><TR><TD CLASS="quote">what about the vss does your odometer act wierd like jumpy. i had that prob car hit vtec turned off and was slow but changed it and it worked perfect have not had a problem yet</TD></TR></TABLE>
No the speedo works fine...actually right on the money i bought a radar gun off of ebay a while back...fun toy to have.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quick_hatch &raquo;</TD></TR><TR><TD CLASS="quote">you replaced the FUEL filter too?</TD></TR></TABLE>
That is something i have not done...or even thought about. no matter how many times you think youve done everything there is always somehting you forget. ill get one in a few minutes and put it in tonight.
Old Sep 20, 2006 | 01:39 PM
ej1vtec's Avatar
Tell me how it goes after you replace the fuel filter.
Old Sep 20, 2006 | 01:41 PM
B16b-EJ8's Avatar
Default Re: (quick_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quick_hatch &raquo;</TD></TR><TR><TD CLASS="quote">Tell me how it goes after you replace the fuel filter. </TD></TR></TABLE>
Will do
Old Sep 27, 2006 | 03:00 PM
ej1vtec's Avatar
any updates
Old Sep 28, 2006 | 09:45 AM
B16b-EJ8's Avatar
I bought the fuel filter but havent put it in yet...doing it this weekend ill let you know.
Old Sep 28, 2006 | 10:43 AM
Sloshy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b-EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">I bought the fuel filter but havent put it in yet...doing it this weekend ill let you know.</TD></TR></TABLE>
waiting..
Old Sep 28, 2006 | 11:59 AM
4g4drb17's Avatar
Default Re: (hatch-E-vanish)
its the ecu, i don't know why but i also have a b16b and i used to run the stock civic type r ecu. i changed to a phearable.net chipped p28 ecu and all the weird hesitation problems went away, in fact it felt like a whole different moter and much more responsive and smooth, also under 4000 rpm with the stock ecu it almost felt like it was bogging when i floored it, now it just pulls. buying that ecu is the best upgrade i ever did.
Old Sep 28, 2006 | 01:34 PM
B16b-EJ8's Avatar
Default Re: (4g4drb17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g4drb17 &raquo;</TD></TR><TR><TD CLASS="quote">its the ecu, i don't know why but i also have a b16b and i used to run the stock civic type r ecu. i changed to a phearable.net chipped p28 ecu and all the weird hesitation problems went away, in fact it felt like a whole different moter and much more responsive and smooth, also under 4000 rpm with the stock ecu it almost felt like it was bogging when i floored it, now it just pulls. buying that ecu is the best upgrade i ever did.</TD></TR></TABLE>
Thanks for the info...i have been looking into a chipped p28 and hondata...i just havent gotten around to purchasing it. Im going to do the fuel filter first then if that doesnt work ill bite the bullet and get the p28
Old Sep 28, 2006 | 03:43 PM
4g4drb17's Avatar
no problem, i was so freakin pleased with my new ecu it wasn't funny, oh and btw if it only does it in third gear its not a fuel filter problem, but it probably needs changing anyway
Old Sep 28, 2006 | 03:56 PM
hondachris1994's Avatar
i had the same issuses, but my motor was untuned with cams and pistons and bolt-ons, got my car tuned from phearable.net and npw the car no longer boggs and hauls *** guy knows his tuning
Old Sep 28, 2006 | 04:08 PM
EX-T's Avatar
Default Re: (hondachris1994)
I'm not thinking that the fuel filter is going to cause hesitation at one particular point. I think you ought to swap ECUs and see what happens.
Old Sep 29, 2006 | 08:36 AM
B16b-EJ8's Avatar
Thanks for the input guys...I will most likely be picking up the ECU next paycheck...i have to solve my vibration problem first. im pretty sure its my axle. it popped out of the tranny a couple of weeks ago and ever since i put it back in i have a vibration under acceleration
dohcgarage@714
Honda S2000
26
Nov 8, 2007 11:29 AM
Deano_D aka "Brick Top"
Oct 28, 2005 08:15 AM
93civicjaydm
Jul 14, 2005 02:59 PM
nicknasty
25
Aug 29, 2003 11:51 PM
x00gsr
17
Aug 13, 2003 03:09 AM
