Where is the 15a fuel injector fuse?
The reason I want to find this fuse is because I want to do a compression test. Could I just unplug the fuel injectors or would I have to unplug the fuse?
there isn't one. injectors are directly controlled by the ecu...you might mean the pgm fi
just remove the spark plug wires from your distributor
unplug the 7.5 amp "backup" fuse in the under hood fuse box. This kills power to the ecu, hence no injectors firing.
BTW make sure that the throttle body is held at WOT while cranking to ensure correct numbers.
tunedek
May 1, 2006 09:15 PM
