OBD1 distributor on OBD0 DPFI harness
Old Sep 18, 2006 | 10:13 AM
PiXeL's Avatar
Default OBD1 distributor on OBD0 DPFI harness
Hi all,
I doing some weird swap.
I have an 93 EDM Civic Dxi with OBD0 DPFI engine (D15B2)
I want to swap to D16Z6 but currently I will run this motor as DPFI non VTEC on the original harness (OBD0). (D16Z6 will be installed with the D15B2 intakes)
The problem is the the D15B2 dizzy doesn't fit the D16Z6 engine.
Is it possible to make the D16Z6 dizzy to work with the OBD0 DPFI harness?
This solution will be temporary until I'll get conversion harness and run the motor with p28 ecu
Old Sep 18, 2006 | 12:48 PM
Rywire's Avatar
Default Re: OBD1 distributor on OBD0 DPFI harness (PiXeL)
revolutions are different in the obd1 dizzy, so no
Old Sep 18, 2006 | 11:06 PM
PiXeL's Avatar
The engine won't start?
Old Sep 18, 2006 | 11:08 PM
salman's Avatar
Default Re: (PiXeL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PiXeL &raquo;</TD></TR><TR><TD CLASS="quote">The engine won't start?</TD></TR></TABLE>
No it wont,
How can you start the engine, when there is no spark?
Old Sep 19, 2006 | 12:35 AM
PiXeL's Avatar
What will cause the dizzy not to give spark?
So there is no way to make it work?
Old Sep 19, 2006 | 04:59 AM
Furyof4's Avatar
Default Re: (PiXeL)
No, just wait to put in the z6 until you have everything else needed for the swap.
Old Sep 19, 2006 | 06:30 AM
ludesrv's Avatar
Z6 dizzy + obd1 dizzy conversion. You will actualy need to do a 100% obd1 conversion. harness, dizzy and injectors.
Old Sep 19, 2006 | 06:44 AM
PiXeL's Avatar
Thanks...
I've read that the Z6 dizzy is different than other OBD1 distributors, is it true?
Because the engine that i'm using is accutally a JDM SOHC VTEC ZC.
I've wrote Z6 because in the US most of you don't see this kind of ZC engine....
and I understood that they are similiar... maybe I was wrong.
How can I identify the Z6 dizzy so I can know if it's the same one?
Or the only thing that matter is that the dizzy is OBD1?
Old Sep 19, 2006 | 04:30 PM
Rywire's Avatar
Default Re: (PiXeL)
They car may start, but run very very poor! with obd0 dizzy.
z6 dizzy is not special, it just fits ur head, you need td42, thats the code for sohc vtec dizzy for d15bvtec, and z6 head
Old Sep 19, 2006 | 05:16 PM
gold_ef's Avatar
why even swap it?
OemED
19
Oct 10, 2016 08:19 AM
acevedo
Apr 2, 2009 07:02 AM
daredeezy619
Nov 21, 2008 04:38 PM
brg2nr
Nov 2, 2005 03:07 PM
CivicManLs
Mar 2, 2005 09:53 AM
