What else do I need?
Old Sep 18, 2006 | 10:09 AM
Dark_Teg's Avatar
Default What else do I need?
I have a 1992 Integra GS. I originally was going to boost this car but i decided to build it up all motor so i could play with it at the track till i get all the turbo parts. I have already purchased all the parts below and I am waiting on the head gasket and ARP head studs to come in so I can get started. Can I bolt all this stuff on and be good to go or is there something else I "need" like a chip or Hondata? BTW: I went with the block guard, ARP studs and Cometic head gasket cause I may spray it in the future.
Thanks,
B18A
*Stock short block
*Block guard
*Ported JG LS head with high lift springs and ferrera valves
*Crower stage 1 cams
*Cometic head gasket
*ARP head studs
*Blox intake manifold and bored throttle body
* 4 into 2 header
*Cold air intake
*MSD cap,coil and wires
*Under drive pulleys
*255 lph fuel pump
GSR Transmission
Quaife LSD
Competition clutch stage 4
Light weight flywheel
ChRiS_p123
Apr 8, 2010 10:27 PM
Day-DayC
May 18, 2006 08:51 PM
Mr_Bojangles
Aug 25, 2004 10:31 AM
sporkcrx
Apr 8, 2004 09:03 PM
servion
Mar 7, 2003 08:35 PM
