LS/VTEC Dyno results
Old Sep 18, 2006 | 06:31 AM
vbherrera's Avatar
Default LS/VTEC Dyno results
My Ls/Vtec on a 92 Civic CX
Put down 189.3 whp and 136.7 tq
My setup:
B18A Engine Block
Bored .75 Over
Micro-Polished Crank
Honed Block
Milled Block
Knife Edged Crank
Machined Crank Journal
Machined Rod Journals
Enlarged Coolant Paths
Shop Peened Rods
PR3 Pistons
ARP Rod Bolts
ARP Head Studs
New Bearings
OEM Head Gasket
ITR Head
Port and Polish Head
3 Angle Valve Job
Ferrea Springs
Ferrea Retainers
GSR Cams
Skunk 2 Pro Race Intake Manifold
Injen Technologies Short Ram Intake
AEM High Flow Fuel Rail
B&M Fuel Pressure Regulator
B&M Fuel Pressure Gauge
Walbro In-Tank 255LPH Fuel Pump
Mugen Headers
2.5” Custom Madrel Bent Exhaust
Apexi World Sport 2 Muffler
Magnaflow Resonator
P28 ECU
Handata S200
Old Sep 18, 2006 | 06:49 AM
vbherrera's Avatar
THe Dyno was made by DynoDynamics
Old Sep 18, 2006 | 07:33 AM
ViF CrX's Avatar
Default Re: (vbherrera)
only 189 you should be making more power than that...
Old Sep 18, 2006 | 07:35 AM
PinkMaggit's Avatar
Default Re: (ViF CrX)
on gsr cams? right........
justr get some cams blox b's. youll hit 200
Old Sep 18, 2006 | 07:41 AM
ViF CrX's Avatar
Default Re: (PinkMaggit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PinkMaggit &raquo;</TD></TR><TR><TD CLASS="quote">on gsr cams? right........
justr get some cams blox b's. youll hit 200</TD></TR></TABLE>
yeah get rid of those gsr cams
where did the type r cams go?
Old Sep 18, 2006 | 07:43 AM
goforbroke's Avatar
MEAT PATTY
That seems to be too good, especially with gsr cams...........
Old Sep 18, 2006 | 08:01 AM
vbherrera's Avatar
ahh i found of they were never type r cams (i got ripped.. oh well)... the cams and injectors are currently maxed out.. i honestly can affod cams right now.. but that is a future upgrade along with new injectors and better headers.. 189 sounds too high? you must be crazy.. do you see all the machine work i have done.. and the compression is bumped up a bit.. thanks for the support from the people not hating..
Old Sep 18, 2006 | 08:06 AM
ViF CrX's Avatar
yeah those are only thing holding your setup back...when get the money just buy those right away but as for the setup now its great already.thats problably where all your money went...
check out this guys ls/v you have more done to it he just has better cams
https://honda-tech.com/zerothread/1748391
Old Sep 18, 2006 | 08:09 AM
black_EM1's Avatar
Community Builder
Community Influencer
Definately. Cams (as long as you have the compression to push them) make a world of difference.
Old Sep 18, 2006 | 08:11 AM
vbherrera's Avatar
i want to upgrade to some jun 3's with the matching jun valvetrain, kteller headers, and i want my head completely machined by port flow (their work is the best IMO), might also look into a bigger throttle body as well
Old Sep 18, 2006 | 09:37 AM
vbherrera's Avatar
ttt
Old Sep 18, 2006 | 01:45 PM
HYBRID FREAK's Avatar
Cant complain on gsr cams.
Old Sep 18, 2006 | 01:48 PM
Phatch99's Avatar
Default Re: (HYBRID FREAK)
Noice #'s!!!! Drop in at least a stage 2 cam n your good to go.....
Old Sep 18, 2006 | 05:08 PM
UncleD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ViF CrX &raquo;</TD></TR><TR><TD CLASS="quote">only 189 you should be making more power than that...</TD></TR></TABLE>
Show me an LS/Vtec running oem pistons and gsr cams making that much power new-jack.
O.P......impressive numbers man
Old Sep 18, 2006 | 06:30 PM
1 bad rex's Avatar
Default Re: (clean rice)
i got a lsvtec with ctr pistons s2s3 cams valve train ls cable tranny nothing worked on the block in a crx tuned at cft with rolo and colombia inside car.( rolo 200 lbs,colombia 175lbs) and on a mustang dyno and i got 191.4 hp and 137.9 tq. not bad for a stock bore and oem parts...soon to get a jdm b16 tranny and see some improvment.for now im cool...
Old Sep 19, 2006 | 03:31 AM
vbherrera's Avatar
yeah im real happy with the numbers, pretty much its all block.. the head really hasnt got to much.. i beleive the extensive machining played a great part in the power put down...
Old Sep 19, 2006 | 05:42 AM
The motor has plenty more potential. Some head work and cams and your breakin 200.
Old Sep 19, 2006 | 07:48 AM
vbherrera's Avatar
soon.. i cant wait to take it to the track... i dont even know what times to expect
Old Sep 19, 2006 | 11:00 AM
-Championship-'s Avatar
76.169.175.137
expect high 13's
but may i ask why put gsr cams???....
and why in the hell would you get a ITR head and gsr cams???!!!!!!!!!!!
you could have gone way past the 200 mark with stage 2 cams....
Old Sep 19, 2006 | 11:28 AM
vbherrera's Avatar
i needed cams and ran out of funds pretty much.. but cams are in the very near future.. the itr head was sold to me with the gsr cams for 400.. cant beat that!
Old Sep 19, 2006 | 10:13 PM
salman's Avatar
very nice Setup with good numbers,
keep it up,
Old Sep 20, 2006 | 05:08 AM
vbherrera's Avatar
my damn disrtibutor is messing up.. im replacing the ignitor today
Old Sep 21, 2006 | 04:40 AM
vbherrera's Avatar
ttt
Old Sep 21, 2006 | 10:52 AM
MikeSarr_GSR's Avatar
how high you spinning that motor?
Old Sep 21, 2006 | 12:02 PM
vbherrera's Avatar
