Reverse grinds.
I have a 91' EF civic coupe. Everytime I throw my car in reverse I grind the gears. The only way I can shift into reverse is unless I shift the gears really slow. I mean thats not a big problem for me to go slow, but sometimes I'm in a hurry and I shift quick when I'm backing up out of a driveway into a busy street. Please note that I am at a complete stop, and I am stepping on the brake. Any suggestions I should check out or replace?
Either your clutch is wearing out or your not pressing the clutch pedal down all the way. When you turn your car off do you leave it in gear? If so, does your car ever roll when you do that? If so it's probably your clutch going out. My Reverse gear does the same thing until I lowered my idle speed and adjusted my clutch under the hood. (the mechanic told me that my clutch was bad, but this is what I did to hold me up) Hope that helps. Peace.
One thing about reverse is that it isn't synchro'd. I know I need to put it into 1st and then reverse sometimes. Other times, I have to put it in reverse and let out the clutch a little til it catches and slides right in. maybe try that, it has worked on all of my cars.
Yes I push the clutch all the way down and when I do leave my car in gear when I park it it doesn't roll, even on hills.
So it seems that my idle is too high? Can anyone tell me where I might be able to modify this? I'll check it out when I get home. Thanks for the suggestions guys.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_1.8T »</TD></TR><TR><TD CLASS="quote">One thing about reverse is that it isn't synchro'd. I know I need to put it into 1st and then reverse sometimes. Other times, I have to put it in reverse and let out the clutch a little til it catches and slides right in. maybe try that, it has worked on all of my cars.</TD></TR></TABLE>
everytime i see this im amazed.. read your owners manual. says to put it in any gear besides 5 then reverse. cant use 5 because its got a lockout so you dont put it in reverse wile flying down the road. THERES NOTHING WRONG WITH YOUR TRANNY!!!!!!!!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n »</TD></TR><TR><TD CLASS="quote">everytime i see this im amazed.. </TD></TR></TABLE>
Amazed at what?
Amazed at what?
There should be a screw that you adjust that has a spring behind it for the idle setting...What you want to do is run the car until your at a normal operating temperature then turn off all your electronics and make sure the ac or blower or anything like that is on and adjust the screw accordingly my car is an 88 DX and the idle speed is supposed to be around 675 to 775 rpms.
Amazed at what?</TD></TR></TABLE>
amazed that no one reads their owners manual. or that so many people dont know that revers doesnt have a synchro
oh and this is one of the first things i learned.. by looking it up when i got my car. thought there was something wrong with my tranny.. key word is looked up(searched)
I started trying this recently. It really works well. Now i don't have to try to get it in gear 12 times, lol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n »</TD></TR><TR><TD CLASS="quote">amazed that no one reads their owners manual.</TD></TR></TABLE> Come on, my car doesn't have cup holders
What makes you think there would be an owner's manual floating around in my glovebox?
lol i kinda thought alot of people dont have a manual with their car. but it does say it right in there. so if reverse grinds your tranny isnt shot.. unless it still grinds after you put it in 1st 2nd 3rd or 4th first.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote"> Come on, my car doesn't have cup holders What makes you think there would be an owner's manual floating around in my glovebox?</TD></TR></TABLE>
my car doenst have cupholders either but i have a manual.
