rsx turbo trouble??
Old Sep 17, 2006 | 09:43 PM
EF_338's Avatar
Default rsx turbo trouble??
my gf just bought a 05 rsx type s
and the guy before her put on a turbo kit
the thing is when the turbo spools up around 4k rpm's
when it gets to around 6k rpms it seems like the turbo cant go anymore
and the car just kinda jerks hard until you shift to the next gear
also got a check engine light and we ran the check engine
and it is running lean?
anyone know what i can do to help fix both these problems?
Old Sep 17, 2006 | 10:04 PM
DC5ITR329's Avatar
Default Re: rsx turbo trouble?? (EF_338)
Kpro and tune.
Old Sep 18, 2006 | 08:16 AM
a2_DC5's Avatar
u need to tune ur air/fuel mixture the right way or eLse it wiLL be running Lean which means that not enough fueL is going into the engine, the engine wiLL get more air than before, which couLd by why that happens when ur at high RPM about to shift..having that happen wiLL cause ur pistons to break b/c of the heat and it wiLL scratch ur cyLinder waLL..but that just assumes onLy the pistons go bad....do u have bigger injectors? and a engine management system? what boost r u running? other mods to the car?
In concLusion we see, N/A is the way to be
Old Sep 18, 2006 | 10:31 AM
Reborn's Avatar
Reborn_
Default Re: rsx turbo trouble?? (a2_DC5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a2_DC5 &raquo;</TD></TR><TR><TD CLASS="quote">u need to tune ur air/fuel mixture the right way or eLse it wiLL be running Lean which means that not enough fueL is going into the engine, the engine wiLL get more air than before, which couLd by why that happens when ur at high RPM about to shift..having that happen wiLL cause ur pistons to break b/c of the heat and it wiLL scratch ur cyLinder waLL..but that just assumes onLy the pistons go bad....do u have bigger injectors? and a engine management system? what boost r u running? other mods to the car?
In concLusion we see, N/A is the way to be </TD></TR></TABLE>
not necessarily. the conclusion is to know exactly what you are buying, or do your own turbo setup and do it right.
it sounds like you and your gf have no idea of the setup, and thats just bad news
Old Sep 18, 2006 | 12:23 PM
KOREAN's Avatar
Default Re: rsx turbo trouble?? (Reborn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reborn &raquo;</TD></TR><TR><TD CLASS="quote">
it sounds like you and your gf have no idea of the setup, and thats just bad news </TD></TR></TABLE>
I second that.
Old Sep 18, 2006 | 06:40 PM
EF_338's Avatar
i figured it needed to be tuned but other than that the turbo was put on by another person
i dont know the set up or anything about it and if anything was upgraded interal wise
seems to me the guy slapped it on and put a turbo timer on it and that was it and called it a day
Old Sep 18, 2006 | 10:42 PM
Reborn's Avatar
Reborn_
take pics of teh whole setup, we will tell you what it is. figure out what ems you are using asap. it looks like youre not using kpro, buy it immediately
Old Sep 19, 2006 | 12:05 PM
hurleyrob's Avatar
Default Re: (Reborn)
What kind of turbo setup is it? And if you know nothing about turbo why would you buy it?
Old Sep 20, 2006 | 12:08 AM
ballerchild's Avatar
Default Re: (hurleyrob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hurleyrob &raquo;</TD></TR><TR><TD CLASS="quote">What kind of turbo setup is it? And if you know nothing about turbo why would you buy it?</TD></TR></TABLE>
Old Sep 20, 2006 | 03:50 AM
25Type-s's Avatar
it looks like the intercooler is mounted upsidedown
Old Sep 20, 2006 | 04:16 AM
Chump2515's Avatar
Default Re: rsx turbo trouble?? (25Type-s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 25Type-s &raquo;</TD></TR><TR><TD CLASS="quote">it looks like the intercooler is mounted upsidedown</TD></TR></TABLE>
thats becuase it prbably is... most hondas are meant to be N/A imo. but you should take it to be tuned and make sure that intercooler is mounted upright
Old Sep 20, 2006 | 08:48 AM
b18a1ef9's Avatar
Default Re: rsx turbo trouble?? (Chump2515)
dude, if it is runnin lean dont floor it anymore. it feels like that at 6krpm because it's running lean, i wouldnt drive it till you get tuned that way hopefully you didnt mess any internals up.
Old Sep 20, 2006 | 10:21 AM
a2_DC5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chump2515 &raquo;</TD></TR><TR><TD CLASS="quote">thats becuase it prbably is... most hondas are meant to be N/A imo. but you should take it to be tuned and make sure that intercooler is mounted upright </TD></TR></TABLE>
I was noticing that too u shouLd have done ur reasearch....and to the owner: throwing a turbo timer doesnt count as tuning!
Old Sep 20, 2006 | 01:07 PM
turbocharge916r's Avatar
DO YOU HAVE AN FMU???????? SAME PROBLEM I HAD WHEN I TURBO MY FIRST CAR, HAD NO FMU. BUT THEN I WAS 14 YEARS OLD AND DIDN'T KNOW MUCH.I HAVE AN RSX TURBO TO AND ITS RUNNING FINE.GIVE THAT FMU AND FUEL PUMP IF YOU DON'T HAVE IT,OR ALL THE FUEL MANAGEMENT.
jdmjin
May 15, 2008 11:20 AM
wannaRSX
Oct 31, 2004 06:12 PM
HairDriedRsx
Aug 12, 2004 01:42 PM
srt4thatazz
Jul 12, 2004 12:38 PM
Jason W
Apr 4, 2002 02:09 PM
