Fail emissions Test - will running the car for 15mins before test help alot???
Old Sep 17, 2006 | 09:33 PM
Totalpkg's Avatar
Default Fail emissions Test - will running the car for 15mins before test help alot???
Heres what I got:
1999 Honda Si
- ITR Swap
- I/H/E - highflow cat
- did oil change, injector cleaner
Limit - Reading
HC: 75 - 179
CO%: 0.42 - 0.56
NO ppm: 576 - 1401
Okay, I forgot to run the car for 15-20 mins, I know dumb, but will running the car get the readings alot lower? I just changed the oil and went in. I plan on using more fuel injector cleaner, cleaning air filter, changing spark plugs and running it for 15-20 mins before test.
Old Sep 18, 2006 | 12:22 AM
itralex's Avatar
Default Re: Fail emissions Test - will running the car for 15mins before test help alot??? (Totalpkg)
High flow cats are junk, run the oem one if possible.
my emissions is up, I hooked mine up to a sniffer before going to the facility and my readings were wayyyyy off the chart. lol
------Limit - Reading
HC: 100 - 1059 (The highest I got)
CO%: .89 - 3.13
Old Sep 18, 2006 | 02:15 AM
Totalpkg's Avatar
Default Re: Fail emissions Test - will running the car for 15mins before test help alot??? (itralex)
Are the OEM cats the same? Is the GSR cat the same as a ITR Cat etc?
Old Sep 18, 2006 | 02:59 AM
88 rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itralex &raquo;</TD></TR><TR><TD CLASS="quote">High flow cats are junk, run the oem one if possible.
CO%: .89 - 3.13</TD></TR></TABLE>
That's not true at all. I passed fine with my magnaflow hi-flo cat.
If you don't heat up your catalytic converter then it isn't working yet. It has to be hot.......really hot, to function correctly.
Old Sep 18, 2006 | 03:06 AM
machgo5go's Avatar
What is the meaning of High Flow CAT if it does not pass any emission standard?
Old Sep 18, 2006 | 03:38 AM
type B16's Avatar
hit vtec a couple of times then get tested again
Old Sep 18, 2006 | 03:43 AM
Splat's Avatar
Collector-o-Guns and Drinker
Take a 20-30 minute drive first - get everything good and hot.
JM17
11
Nov 1, 2006 07:34 PM
Totalpkg
Sep 17, 2006 09:38 PM
_Cyclone_
Jun 13, 2005 09:30 PM
Devlins 91LS
Nov 18, 2004 02:03 PM
Bizarre
Aug 9, 2003 06:46 AM
