Injector stuck Or else,
Old Sep 17, 2006 | 08:20 PM
salman's Avatar
Default Injector stuck Or else,
Hi all.
I have a B16a, 3 days back it started to suck fuel as hell, gave me 6 MPG,
and Plug number 1 got dead, I open the plug to see, it was clean but it was completely covered with un burned fuel, I cleaned it and put it back, but the problem remains, I waited 20 mins for a friend to come and check, he came we started it again, cyld#1 was not working, but it started working after some tweaking it started working, took it for a ride, it was ok, but it failed again,
I think my injector is stuck,
While, I was doing the wiring, I didn’t connect the injectors with a really, and connected it with IGn1,
Could this be the reason behind injector problem?
Thanks,
Old Sep 17, 2006 | 08:28 PM
jaycrxsi's Avatar
Default Re: Injector stuck Or else, (salman)
I don't think so because it would be back firing if you had a stuck injector i would check the fire running to the #1 plug
Old Sep 17, 2006 | 08:37 PM
salman's Avatar
Default Re: Injector stuck Or else, (jaycrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaycrxsi &raquo;</TD></TR><TR><TD CLASS="quote">I don't think so because it would be back firing if you had a stuck injector i would check the fire running to the #1 plug</TD></TR></TABLE>
checked and replace the wire, they where ok,
Checked the firing on #1 on both sides, dizzy and plug, perfect and strong,
Old Sep 17, 2006 | 08:40 PM
jaycrxsi's Avatar
how did you get it to start working again the first time
Old Sep 17, 2006 | 08:45 PM
salman's Avatar
started on its own, my friend dc the plug wire and reconnected it, done this for 2 times and it started working,
you wont belive me it, how the fuel guage is goinging down
Old Sep 18, 2006 | 08:52 PM
salman's Avatar
Default Re: (salman)
last night i Disconected the injector plug and powered it directly to check,
the injector was clicking, then i unplung another injector to check, the other one was clicking loud,
checked this for few time and i am sure there was 50/50 diffrence in injector clicking sound,
Old Sep 18, 2006 | 09:52 PM
salman's Avatar
Is there any way to check the injector, or test them, let me know.
Old Sep 18, 2006 | 10:59 PM
azndough's Avatar
Man does this sound like a problem i had before. Try this check the prongs on the injector clip, make sure there gettin contact with the injector. Just a thought as i had this problem with my b16 after a rebuild.
Old Sep 18, 2006 | 11:05 PM
salman's Avatar
Default Re: (azndough)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azndough &raquo;</TD></TR><TR><TD CLASS="quote">Man does this sound like a problem i had before. Try this check the prongs on the injector clip, make sure there gettin contact with the injector. Just a thought as i had this problem with my b16 after a rebuild.</TD></TR></TABLE>
I think they are making contact, else there wont be any fuel on the injectors.
I said that the car is eating fuel as hell,
Old Sep 19, 2006 | 02:52 AM
salman's Avatar
bump!
NevinJoe
Sep 17, 2025 12:50 PM
RxglassJAw
Jun 16, 2008 06:33 AM
BB6racer
Jan 14, 2006 07:17 PM
RaysBoomBoomLude
Sep 13, 2005 05:29 PM
kb58
Sep 25, 2003 08:31 PM
