rear disk
I searched but cant get right answer, I got a 96 ek and i want to know if i can use 92 teg rear trailing arm for the disk, i know ima nedd the cables out of an si,
thanks i advance.
thanks i advance.
Yes. However, you don't need to use the entire trailing arms - you can just unbolt the hub assemblies from the DA arms and bolt them up to your EK arms. If you do end up using the DA arms, just keep in mind that the DA Integra has a larger diameter trailing arm bushing than your EK, so if you ever replace the TA bushings, make sure you order ones that are specific to '90-93 Integra.
c|rop3asy==[]
May 23, 2011 12:30 AM
ncVTEC1313
Jun 3, 2004 05:14 PM
