IACV issues on GSR Swap
Old Sep 17, 2006 | 05:33 PM
Superdragr45's Avatar
Default IACV issues on GSR Swap
i recently swapped my LS/VTEC for a complete GSR motor. it is throwing a code 14, which is for the IACV.
1st, i cleaned it out with carb cleaner and let it dry. still had the code. finally, i decided to get another from a local dismantler, and it still has the same problems. anyone else have any advice for me soo i can eliminate this problem???
Old Sep 17, 2006 | 05:43 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default Re: IACV issues on GSR Swap (Superdragr45)
Chances are if both IACV seem bad, then u may have a vacuum leak somewhere. Check ro make sure all vacuum lines are routed correctly. Also check for cracks in the intake manifold. That's what gave me my code 14, and I too went through 3 good IACV's until I discovered that crack.
Old Sep 17, 2006 | 06:47 PM
Default Re: IACV issues on GSR Swap (rukawa1one)
could a bad TB gasket cause it?? i want to check that as well. wat are all the places to check for a vacuum leak???
Old Sep 17, 2006 | 06:50 PM
SkoundrelUSA's Avatar
cute little bastard
I had the same problem when I did my swap. Never threw a code before but won't go away after the swap right?
Ended up plugging the wrong sensor plug to the IACV. Got it mixed up with the knock sensor one. Swap around the sensor plugs. Might be it.
Old Sep 17, 2006 | 06:57 PM
Default Re: IACV issues on GSR Swap (SkoundrelUSA)
i had that same thought that the plugs might be switched around...............will have to try that. but, in my mind, wouldnt it throw a knock code if they were swtiched???
Old Sep 17, 2006 | 06:59 PM
cute little bastard
Depends on ECU I guess. I have a P28 so it only threw the IACV code (14)
Old Sep 17, 2006 | 10:57 PM
the main thing is that im running a 99 SI ECU and iim OBDII
D Grade
Aug 14, 2016 07:57 PM
94allmotor
24
Sep 8, 2007 08:08 PM
EGk3nrock
Apr 27, 2007 06:59 AM
justinxecushyn
Apr 2, 2006 10:29 AM
Flyingchopstick
Jul 14, 2005 11:24 AM
