Another ECU Question
Old Sep 17, 2006 | 04:55 PM
gworthyunit's Avatar
Default Another ECU Question
I want to run an OBD-1 ECU in my HX. Could I run a VX ECU in my car with no CEL's and no problems? I know both HX and VX use 5 wire O2 sensors. I'd assume the HX and VX fuel maps and ignition tables would be the same or at least close to the same since both motors are geared towards efficiancy.Reason for the question is I need an ECU that can be chipped/tuned later on down the road
thanks guys!
Old Sep 17, 2006 | 07:13 PM
Default Re: Another ECU Question (gworthyunit)
bumpitty bump!
Old Sep 17, 2006 | 07:16 PM
BauleyCivic's Avatar
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gworthyunit &raquo;</TD></TR><TR><TD CLASS="quote">I want to run an OBD-1 ECU in my HX.</TD></TR></TABLE>
Why?
Old Sep 17, 2006 | 07:39 PM
So I can tune it for my JRSC. I said why at the end of the original post.
Old Sep 17, 2006 | 07:42 PM
cambopheonix56's Avatar
Default Re: (gworthyunit)
Cant you just send in your ecu to like hondata and they can reflash it for superchargers since they are belt driven?
Sorry I am of no further help.
Old Sep 17, 2006 | 07:59 PM
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gworthyunit &raquo;</TD></TR><TR><TD CLASS="quote">So I can tune it for my JRSC. I said why at the end of the original post.</TD></TR></TABLE>
Yeah, why don't you worry about it then. I'm assuming the JRSC is not going on the D16Y5...
Old Sep 18, 2006 | 04:43 AM
Default Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">I'm assuming the JRSC is not going on the D16Y5...</TD></TR></TABLE>
You know it is!
Thanks for the help guys, I'll look into a reflash
Old Sep 18, 2006 | 04:59 AM
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gworthyunit &raquo;</TD></TR><TR><TD CLASS="quote">You know it is!</TD></TR></TABLE>
Old Sep 18, 2006 | 05:12 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
Lol. Y5 is not a bad motor. I don't want to swap but I want to keep up with traffic lol.
Old Sep 18, 2006 | 01:56 PM
UberMunkey's Avatar
that doesn't sound like such a good idea.
Old Sep 18, 2006 | 02:32 PM
Relic1's Avatar
get a P28 and tune from there.
the P07(VX ECU) is generally not an ECU that takes to chipping very well.
There are a few versions that can be chipped but they share the same board as the P28/P06/P05 ECUs. Which means one MCU which means 4-wire O2.
kzelisko
Feb 12, 2010 10:06 AM
imzjustplayin
Jun 2, 2008 09:43 PM
JDM_Spec_SI-R
Nov 10, 2006 05:44 AM
Import13alla
May 28, 2004 06:37 AM
95gsr
May 18, 2003 11:29 AM
