Oil Light on when idling
Old Sep 17, 2006 | 12:15 PM
sublimenerd's Avatar
Default Oil Light on when idling
The oil light flashes then stays on at idle. I have good oil pressure and have plenty of oil. anyone else have this problem?
Old Sep 17, 2006 | 05:19 PM
Kyoto now's Avatar
Default Re: Oil Light on when idling (sublimenerd)
Could be a faulty oil pressure sending unit, though I've never heard of this being a problem on the rsx, or any honda for that.
Old Sep 18, 2006 | 11:54 PM
Kyoto now's Avatar
Default Re: Oil Light on when idling (DA9 Purist)
did you figure it out?
Old Sep 19, 2006 | 09:47 AM
Not yet trying to figure it out though anymore suggestions?
Old Sep 19, 2006 | 12:14 PM
Reborn's Avatar
Reborn_
so the oil light is only on at idle? when you start driving it goes away?
it only makes sense that if you in fact have plenty of oil and good oil pressue, the sensor must be screwed up.
Old Sep 19, 2006 | 01:15 PM
Perfectionist's Avatar
How do you KNOW you have good oil pressure? Did you check it with an external guage? An idling engine will pump less than one at higher RPMs, and that would eplain why the oil light goes out. If you did do a check with a real pressure guage, never mind. If not, I suggest you park it and get the problem corrected unless you want to blow the engine.
Old Sep 19, 2006 | 01:29 PM
Default Re: Oil Light on when idling (Perfectionist)
I took it to acura and the oil pressure is fine when I take off it goes away. I gotta call them tomorrow and see what they say.
Old Sep 20, 2006 | 05:58 AM
The Tech-1's Avatar
The only reason I know the oil light flashes is when you're getting low on oil
Old Sep 20, 2006 | 12:41 PM
Reborn's Avatar
Reborn_
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sublimenerd &raquo;</TD></TR><TR><TD CLASS="quote">I took it to acura and the oil pressure is fine when I take off it goes away. I gotta call them tomorrow and see what they say.</TD></TR></TABLE>
keep us updated, im interested to find out
Old Sep 20, 2006 | 01:11 PM
velocitytrends's Avatar
I would like to know as well.
Old Sep 20, 2006 | 02:17 PM
Acura didn't say anything when you took it there and they checked the oil pressure because of on oil light at idle? Something doesn't make sense here.
Old Sep 21, 2006 | 07:44 PM
Default Re: (velocitytrends)
I found out that the light is broken and shorts out. Acura told me there is nothing wrong mechanically. Thanks for the advice guys
Old Sep 22, 2006 | 10:36 AM
Kyoto now's Avatar
Default Re: (sublimenerd)
Old Sep 22, 2006 | 01:45 PM
Reborn's Avatar
Reborn_
good to hear. you may want to get it fixed so that if it does come on if you happen to lose oil, you wont think nothing of it.
Old Sep 22, 2006 | 04:26 PM
Default Re: (Reborn)
i agree so you how do you remove the cluster panel?
Old Sep 24, 2006 | 02:33 PM
Reborn's Avatar
Reborn_
its very simple, remove the cover under the steering column (there are 2 **** things, twist them 90 degrees any direction and the panel should come righ off)
now lay on your back and look up, its hard to find but there are 2 screws that keep the cluster in place. remove those screws. now reach from underneath and push out the cluster. not too far, the harnesses are still connected, disconnect the 2 harnesses and out it comes. once you locate everything, its a 2 minute job.
replacing the light may prove very difficult, however.
Old Sep 25, 2006 | 02:33 AM
appreciate it we'll let you know how it goes
thefew
Oct 9, 2013 12:34 PM
Retribution
Apr 1, 2009 06:22 PM
lonewsome
Jan 1, 2009 01:42 PM
xlasianizelx
May 1, 2008 07:42 AM
toyH22
May 31, 2006 02:05 PM
