Car Wont Start need Help PLease!.
Old Sep 17, 2006 | 11:13 AM
88EfSedan's Avatar
Default Car Wont Start need Help PLease!.
my car wont start, my head gasket blew, when i checked my oil it was a coffee color, i changed head gasket with new one, and my car wont start, i have a timing gun, but its no use unless i get this thing started. it will crank crank and crank, but it wont turn over. does anybody know what the problem can be? oh and when i put my head back on, my belt on the cam gear is loose on the right side, could that be a problem? its the stock motor btw. Thanks For Any Advice.
Old Sep 17, 2006 | 11:26 AM
si90rex's Avatar
Default Re: Car Wont Start need Help PLease!. (88EfSedan)
i told u get a manual it will show u how to put the belt in time. not the motor. u need to get the head and the motor at top dead center. (tdc) put the belt on get it tight and it might work but u probly bent a couple of valves. u made the same post fri. i told u the same thing. u can't just put the belt on the head and start it u MOST line up the crank pulley and the cam gear first!
Old Sep 17, 2006 | 11:33 AM
88EfSedan's Avatar
Default Re: Car Wont Start need Help PLease!. (si90rex)
alright, i just got the haynes honda bible, im about to read that, thanks again si90rex. do you have aim? if so can i get your aim IM?
Old Sep 17, 2006 | 11:39 AM
si90rex's Avatar
ya it skate_on_4ever@hotmail.com i'm not a skater any more that was like 5th grade. but hit me up. i can get some pics later maybe
Old Sep 17, 2006 | 11:59 AM
si90rex's Avatar
oo and by the way u can IM me here there a IM button under ur name and pic but since ur in trial mode i don't know if u can get them. i'll send u one but u have to have the any pop blockers off other wise u can't recieve them.
Old Sep 17, 2006 | 12:34 PM
88EfSedan's Avatar
I read the message you sent in the IM but it said that, i did have permission to reply back. To describe the color to you, its like when you put creamery in you coffee and it gives it that light color.. im about to go outside, and do what you told me about the [ TDC ] .. Thanks man i really appreciate you helping me.
Old Sep 17, 2006 | 01:18 PM
si90rex's Avatar
its hard to explain the oil thing, sound like oil and coolant mixed, if thats the case, not good. but not to be a downer but u mostly like have some bent valves, if u go by the book u should be fine. but u all ready turned it over a couple of times there no telling what happend. hit me up if u got more question. oo and the old head might work, but it hard to say.
cloudconnected85
Mar 11, 2009 09:05 PM
coreyhayman
Dec 30, 2006 05:45 PM
JDMCivicEF9
Jul 31, 2005 06:50 PM
92HB_HB
Feb 12, 2005 07:31 PM
306gun
11
Nov 13, 2002 09:15 PM
