psycho wheel hop
Old Sep 17, 2006 | 10:32 AM
superbangkok's Avatar
Default psycho wheel hop
95 Honda Civic: I had a B18C put in with complete front end etc. ... also had a heavy duty racing clutch put in.
The problem is when I jump on it banging gears, there is some severe wheel hop or shaking sensation in first, second and third gears. A friend says he thinks the flywheel wasn't resurfaced and that is the problem. Or could it be motor mounts?
The racing shop here in Thailand who did the motor/tranny install just says it's the racing clutch and that is how it is (lazy asses), i don't agree.
opinions appreciated.
Modified by superbangkok at 11:42 AM 9/17/2006
Old Sep 17, 2006 | 10:50 AM
Sloshy's Avatar
need more info is it the wheel hopping or the motor?
Old Sep 17, 2006 | 05:12 PM
Default Re: (hatch-E-vanish)
it seems to be wheel hop, it is very harsh and feels like the engine is going to jump out of the car.
but normal acceleration with gear shifts are rather smooth.........
Old Sep 17, 2006 | 05:16 PM
just concerned as the two motor mounts in the front look tight, however there are mounts inside on both sides, but only one side has extra rubber bushings. I am wondering they obsorb what i'm describing, and if i'm missing something.
will take some pics of the mounts today.
Old Sep 17, 2006 | 05:34 PM
StolenTeg's Avatar
Default Re: (superbangkok)
get a traction bar and you wont have to deal with that again, EVER
Old Sep 17, 2006 | 05:42 PM
FalkenSiR's Avatar
Default Re: (StolenTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StolenTeg &raquo;</TD></TR><TR><TD CLASS="quote">get a traction bar and you wont have to deal with that again, EVER</TD></TR></TABLE>
True, BUT if this is in fact abnormal, then it's a problem that has to be addressed. I say ride in somebody elses car with a similar setup (approx hp) and compare your car to theirs first.
Old Sep 17, 2006 | 05:50 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default Re: psycho wheel hop (superbangkok)
Free bump for a fellow Thai What u are reffering to is tranny chatter. The clutch u have is so aggressive that if u dont keep the revs high enough it will grab prematurely. U either have to get used to reving it to what the clutch demands or get a new clutch. I had one like a stage 4 clutch on a next to stock motor, it chattered all the time till i adapted to it. The clutch disc only lasted like a year and a half as well. A street setup clutch would probably be best for u. Right now I'm running a stage 1 exedy with ITR flywheel. Feels pretty close to stock except the pressure plate is a bit heavier. No chatter though
Old Sep 17, 2006 | 05:55 PM
chunkybs's Avatar
i have a EG hatch with D16 with I/H/E, it's also gutted and i get really bad wheel hop any time i launch also. i was told that it's because my car is so light.
Old Sep 17, 2006 | 06:18 PM
t0p_sh0tta's Avatar
Default Re: (chunkybs)
Upgrade the motor mounts and check for worn suspension components.
Stiffening up the above will make a big improvement.
Oh yea, make sure you're using decent tires.
Old Sep 17, 2006 | 06:20 PM
thanks for the advice all, rukawa1one maybe you are right - boon racing put in the race clutch and it really grabs. however, driving around bangkok traffic and keeping the revs up gets to the left leg after awhile.
your clutch specs sound reasonable and will get that next time around (1 year or so)
Modified by superbangkok at 10:51 PM 9/17/2006
Old Sep 17, 2006 | 06:21 PM
spoonracer84eg's Avatar
Default Re: (t0p_sh0tta)
Clutch chatter
Old Sep 18, 2006 | 09:33 PM
rukawa1one's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superbangkok &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the advice all, rukawa1one maybe you are right - boon racing put in the race clutch and it really grabs. however, driving around bangkok traffic and keeping the revs up gets to the left leg after awhile.
Modified by superbangkok at 10:51 PM 9/17/2006</TD></TR></TABLE>
Oh hell ya, thats got to be the worst! I've driven on the streets there b4 and it sucks ***** especially in sukumvit
I just sent my friend there an OEM type R lip for his 98 integra front end. Maybe u have seen him around, he drives a yellow integra with US 98 front end.
Old Sep 18, 2006 | 09:37 PM
EGwhat!!!'s Avatar
best advice on this thread
Old Sep 18, 2006 | 10:01 PM
Archidictus's Avatar
Unceasing Measure
I guess you've learned the valuable lesson of not putting too much clutch in a street car, huh?
Old Sep 19, 2006 | 08:17 AM
Default Re: (rukawa1one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one &raquo;</TD></TR><TR><TD CLASS="quote">
Oh hell ya, thats got to be the worst! I've driven on the streets there b4 and it sucks ***** especially in sukumvit </TD></TR></TABLE>
yeh luckily i only have to deal with bkk traffic for one day a week, the 1 hour trip there and back is sweet -- there is no speed limit in thailand.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta &raquo;</TD></TR><TR><TD CLASS="quote">Upgrade the motor mounts and check for worn suspension components.
Oh yea, make sure you're using decent tires.</TD></TR></TABLE>
i have been replacing stock bushings with polyurathane, will get to the motor mounts next -- for piece of mind
tires are goodyear z-rated
will look into a traction bar, any URLs recommended for ordering this ?
civicsaremean
18
Jul 23, 2007 11:17 AM
mr_nemesis2003
18
Apr 26, 2006 02:33 PM
jbscivichb92
Oct 29, 2004 07:49 AM
b18c51032000
Apr 18, 2003 03:55 PM
techboy3244
Mar 21, 2003 06:04 AM
