Ignition switch on on 98 stuck, won't turn.
Old Sep 17, 2006 | 08:10 AM
dieselgg's Avatar
Default Ignition switch on on 98 stuck, won't turn.
A search of the threads only yielded electrical issues related to the ignition switch but nothing mechanical.
For quite a while, when I first insert the key, I am not able to physically turn the switch to start the car. It's as if the steering wheel is locked, but it isn't. Even with the steering wheel loose and all, I have to fight with the switch before I can turn the switch.
Could there be a problem with the tumbler in the ignition switch which?
Any suggestions would help, thanks.
Old Sep 17, 2006 | 11:13 AM
mgags7's Avatar
yea the tumbler isnt fully releasing the cylinder to turn....maybe go in there and clean it out if you know what youre doing....or you could just gte a new one....
Old Sep 17, 2006 | 11:22 AM
dieselgg's Avatar
Default Re: (mgags7)
Thanks boss!
Old Sep 17, 2006 | 06:55 PM
madcatz's Avatar
actually there is a Factory Service Recall in the Ignition for the 5th gen.
Barf Hat
Oct 9, 2019 05:45 AM
moneyman0627
Apr 18, 2013 10:36 PM
badfish2282
May 15, 2009 08:45 PM
carnifex
Mar 3, 2005 01:26 PM
