Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Synthetic Oil In SI
Old Sep 17, 2006 | 07:43 AM
black06si's Avatar
Default Synthetic Oil In SI
My car has about 600 miles how long before i change to synthetic oil. they say if you wait to long to change, the car might start acting up,, so i guess its a two part question, A: how long? B: Is it true that it will act up?
Old Sep 17, 2006 | 08:11 AM
spoonlongblock's Avatar
Default Re: Synthetic Oil In SI (black06si)
one it will not start acting up where did you hear that. I work for Lexus and we add it every 1000 miles as when it comes in for the 1k service. I would add it whenever you do your first oil change.
Old Sep 17, 2006 | 09:36 AM
gus738's Avatar
Default Re: Synthetic Oil In SI (spoonlongblock)
the moment i got the car i changed the oil to mobile 1 full sytetic oil with an k & n oil filter fellow by a aem cai . snytetic oil best
i bought it off my cuz and paid evertying ( he couldnt afford ) i think i changed oil around 1300 miles ...
Modified by gus738 at 10:52 AM 9/17/2006
Old Sep 17, 2006 | 09:50 AM
nolia3du's Avatar
Default Re: Synthetic Oil In SI (gus738)
Why would you switch the oil right when you get the vehicle. The engine doesn't come from the factory with synthetic, so the engine needs to be broken in before you switch. If you did switch before the engine is broken in the piston rings won't wear in properly and won't seal. Synthetic is a beter oil, but if it is put in before the break in period, you'll have problems down the line.
Old Sep 17, 2006 | 10:02 AM
BAR296's Avatar
Default Re: Synthetic Oil In SI (nolia3du)
did my 1st oil change at about 3200(20%) at the dealer with regular oil. i just did my second oil change at about 6300(15%) and switched to Mobil1 5w-30 and she's runnin beautifully.
Old Sep 17, 2006 | 10:04 AM
blue2ksi's Avatar
theres special additives in the oil comes from the factory that help the break-in process. the manual advises you NOT to change your oil quickly the first time and to leave the factory oil in.
Old Sep 17, 2006 | 12:16 PM
BAR296's Avatar
Default Re: Synthetic Oil In SI (blue2ksi)
Yes but it also says that if your meter gets to 15-20% that it should be changed.
Old Sep 17, 2006 | 01:24 PM
modifyORdie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue2ksi &raquo;</TD></TR><TR><TD CLASS="quote">theres special additives in the oil comes from the factory that help the break-in process. the manual advises you NOT to change your oil quickly the first time and to leave the factory oil in. </TD></TR></TABLE>
exactly...your not supposed to change your oil for the first time until 5000 miles
and it also says in the manual that synthetic has no advantages in honda motors....
Old Sep 17, 2006 | 01:26 PM
Default Re: Synthetic Oil In SI (BAR296)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BAR296 &raquo;</TD></TR><TR><TD CLASS="quote">Yes but it also says that if your meter gets to 15-20% that it should be changed.</TD></TR></TABLE>
how hard are you running it for your oil life to go down quickly? your only supposed to use about 20% for every 1000 miles = 0% every 5,000 miles which is the recommended change time
Old Sep 17, 2006 | 01:47 PM
gus738's Avatar
Default Re: Synthetic Oil In SI (modifyORdie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by modifyORdie &raquo;</TD></TR><TR><TD CLASS="quote">
how hard are you running it for your oil life to go down quickly? your only supposed to use about 20% for every 1000 miles = 0% every 5,000 miles which is the recommended change time</TD></TR></TABLE>
where in the manuel does it say that?
Old Sep 17, 2006 | 03:08 PM
DougNuts's Avatar
When I get my Si, or any new car, I will not switch to synthetic until 10-15K miles.
You want your motor to be broken in before you make the switch. I personally do not believe that it's ever too late to switch to synthetic oil, but you can do it too early. I switched my 5.0 Mustang to synthetic at 145K miles and switched back and forth several times and I had no trouble hitting 200K miles in that car. And yes, I drove it hard, often.
Honest question: As far as the manual saying that there are no advantages in a Honda motor, does anyone know why it says that? Seems to me that there is plenty of evidence to support that synthetic oil is greatly superior, so how does Honda build a motor that doesn't see any benefit, either in reduced wear or free power?
Old Sep 17, 2006 | 03:50 PM
Demonis's Avatar
I switched it on my first change, 28xx miles... and believe me, the engine was broken in heh heh heh.
Old Sep 17, 2006 | 04:05 PM
Default Re: Synthetic Oil In SI (DougNuts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DougNuts &raquo;</TD></TR><TR><TD CLASS="quote">Honest question: As far as the manual saying that there are no advantages in a Honda motor, does anyone know why it says that? Seems to me that there is plenty of evidence to support that synthetic oil is greatly superior, so how does Honda build a motor that doesn't see any benefit, either in reduced wear or free power? </TD></TR></TABLE>
I think it has something to do with the way theyre coated on the inside but i dont know...i always use royal purple anyways, but i dont know if i want to take the fg to the dealer for service..never had a brand new car before
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gus738 &raquo;</TD></TR><TR><TD CLASS="quote">where in the manuel does it say that? </TD></TR></TABLE>
if you look in the manual under service it says oil change should be every 5,000 miles...the rest of the calculations are just simple math. 5000 miles = 20% every 1,000 miles
Old Sep 17, 2006 | 04:11 PM
gus738's Avatar
if you look in the manual under service it says oil change should be every 5,000 miles...the rest of the calculations are just simple math. 5000 miles = 20% every 1,000 miles</TD></TR></TABLE>
is that royal purpose any good either? lol , i never had a new car too , btw NO WHERE in the book it says to not use syntici oil or it doesnt have any advantages...
incase you dont read syntiicl oil meets or exceeds oem requirerments...
i dont put oil that is not known ... i always use mobile 1 full syteitnc or castrol full syticic
Modified by gus738 at 5:22 PM 9/17/2006
Old Sep 17, 2006 | 04:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gus738 &raquo;</TD></TR><TR><TD CLASS="quote">is that royal purpose any good either? lol , i never had a new car too , btw NO WHERE in the book it says to not use syntici oil or it doesnt have any advantages...
incase you dont read syntiicl oil meets or exceeds oem requirerments... </TD></TR></TABLE>
royal purple is the ***** its great stuff and always comes out clean. i really do remember reading somewhere about synthetic oil, ill have to go look for it later but im too lazy right now
Old Sep 17, 2006 | 08:12 PM
DeDonDeRosa's Avatar
just use synthetic it will not hurt the car its BS 3k miles change it!!!!!!!
just like how vw oil changes say dont do them 7500 miles!!!!! never!! 3k you'll never have a prob
and listen if mobil 1 is good enough to come in
Camaro SS's
Vettes
Porsches etc from the FACTORY ITS GOOD ENOUGHT FOR YOUR HONDA!!!!
Old Sep 17, 2006 | 09:46 PM
gus738's Avatar
Default Re: Synthetic Oil In SI (DeDonDeRosa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeDonDeRosa &raquo;</TD></TR><TR><TD CLASS="quote">just use synthetic it will not hurt the car its BS 3k miles change it!!!!!!!
Camaro SS's
Vettes
Porsches etc from the FACTORY ITS GOOD ENOUGHT FOR YOUR HONDA!!!!</TD></TR></TABLE>
i didnt quite get you &lt; i normaly change oil every 3 k miles and i always use full syteitc oil , but what you mean about mobile 1 is good enought? its the best... or what you mean???? again im confused
Old Sep 18, 2006 | 03:34 AM
sythentic comes in all those cars stock from the factory they dont use regular oil
basically just change your oil every 3k miles and use synthetic~~!!!!!!
Old Sep 18, 2006 | 07:30 AM
fuhsm1's Avatar
You have to always consider the sales side of all vehicle manufacturers, including Honda. Saying that the oil only needs to be changed every 7500 miles instead of every 3000 miles effectively cuts maintenance costs for oil changes in half, which makes the car cost the buyer less money in the long run.
The engineers at Honda unfortunately don't write the owner's manuals, so the recommendations in there aren't always the best to follow.
Stick with synthetic changes every 3k and you'll be good to go.
Old Sep 18, 2006 | 07:38 AM
DaveSi677's Avatar
Default Re: Synthetic Oil In SI (fuhsm1)
Yes there is special additives in the oil that the car came with. Regular oil is a good oil for breaking in a new engine after that I would switch to syntectic. I really like Motul out of all the oils I have used.
Dave
Old Sep 18, 2006 | 08:02 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeDonDeRosa &raquo;</TD></TR><TR><TD CLASS="quote">sythentic comes in all those cars stock from the factory they dont use regular oil
no it doesnt
Old Sep 18, 2006 | 09:20 AM
DougNuts's Avatar
I believe that most cars that come factory filled with Mobil 1 have had the motor run in before they fill it with synthetic.
In the same vein, you are aware of the oil consumption issues with the Z06's right?
I'll say it once again, you can switch to synthetic too early. I am going to play it safe and do it on the 2nd or 3rd oil change.
Finally, if you are running synthetic oil, you do not have to change it every 3K miles. An independent study was done which showed that synthetic can be run for a long time, 10K+ miles, and still perform within spec. If you're going to change it every 3K miles, just run normal oil.
My advice on synthetic oils, for anyone not stuck in a rut of misinformation, is as follows:
1. Run a high quality oil filter, like Mobil 1.
2. Change the filter every 3-4K miles.
3. Change the oil every 6-8K miles.
That's just what I plan on doing though......
Old Sep 18, 2006 | 10:16 AM
todaCspec's Avatar
When you just change oil filter and not oil, it doesn't start to get messy from oil pouring out? I'm guessing you do it when it's cold so all of the oil sits on the bottom.
Old Sep 18, 2006 | 10:19 AM
DougNuts's Avatar
Default Re: Synthetic Oil In SI (todaCspec)
I don't have an Si yet, so I'm not sure where the filter is on a K-series motor.
But, yes, I change the oil filter on our D-series motors after it has sat for a while. It doesn't make any more of a mess.
Old Sep 18, 2006 | 08:00 PM
my friend had an 06 type-s and switched to synthetic around 3500 miles and beat the crap outta his car every day and never had a problem and never burned oil!!!
