blew motor (huge hole in oil pan)
was cruising home last night at 1am doing 110km/h in 5th when all of a sudden boom, car shuts off and the cabin fills with smoke, i pull over to theside of the road and me and my girlfriend get out and theres a huge puddle of oil under my car. I get underneath and look and theres a huge hole in the bottom of my oil pan, i can feel something in the pan when i stick my finger in there moving around. the car wont start now either, now, i also checked the timing belt and its gone. I had the car in the shop 2 weeks ago getting a brand new timing belt and water pump installed and its snapped. This shop better be replacing my motor, my question is if the belt snapped would it send something flying through my pan to put the huge hole in it? I cant believe this happend the car was just in the shop 2 weeks ago being gone over, ridiculous and it only had 170,000k's
Well obviously you threw a rod. You're going to have to pull the whole engine to make sure the block's not fucked up. Either way I'd get it bored and sleeved. What MAY have happend with your timing belt was b/c the rod threw it wedged and jammed up the crank shaft which basically locked the crank gear while it's spinning at whaetver rediculously fast rate and the belt skipped over and got shredded. That's the only way <u> I </u> can draw a connection to throwing a rod like taht. Timing belts going usually result in bent valves, or weak running.
Sorry to hear about that man
Weird though, shouldn't have happend like that. What kind of non OEM (from a different honda) or aftermarket parts do you have on the car (everything)? Miles are rediculously low for throwing a rod like that, and the timing belt deal 2 weeks ago sounds a little fishy IMO.
motor is a completly stock d16y8, yeah it was my friend car and when she got it back from the shop previously after the belt being done it was running shitty and the motor was ticking badly, she took it back and complained that it was running worse then when she took it to them and then now this.
The timing belt and spinng a rod bearing are not related.
More than likely, you're screwed.
Edit:
If the belt snapped, you probably would have been some valves, and that would be about it.
Edit:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coreyhayman »</TD></TR><TR><TD CLASS="quote">motor is a completly stock d16y8.</TD></TR></TABLE>
Known for bad oiling and spun rod bearings
Sorry man, I don't think the timing belt has anything to do with it, although your friend's issue with it "running crappy" might have been because it was off a tooth or so. Still, that won't blast a rod through the oil pan.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">
Sorry man, I don't think the timing belt has anything to do with it, although your friend's issue with it "running crappy" might have been because it was off a tooth or so. Still, that won't blast a rod through the oil pan.</TD></TR></TABLE>
So that's it, eh? I didn't think they had anything to do with each other. Above is the crappy connection of being the only way they could have been related. As it's possible but very very very very unlikely. Oh well, glad to know I wasn't completely out of my mind, I didn't think they were related.
Sorry dude, ur engine is **** fucked.
Sorry man, I don't think the timing belt has anything to do with it, although your friend's issue with it "running crappy" might have been because it was off a tooth or so. Still, that won't blast a rod through the oil pan.</TD></TR></TABLE>So that's it, eh? I didn't think they had anything to do with each other. Above is the crappy connection of being the only way they could have been related. As it's possible but very very very very unlikely. Oh well, glad to know I wasn't completely out of my mind, I didn't think they were related.
Sux man. About 3 months ago I went to a shop to change my oil (To lazy to do it myself.) So o/change was complete, went home to pick up my lil bro's to take them to football practice. On the way there, I see a big cloud of smoke come out of my exhaust. I was like "wtf." Went home after dropping them off and when I arrived at home, I saw a big puddle of fresh oil in my driveway. All I thought about was "That Fu$$er didn't tighten up the oil pan bolt." Checked the oil pan and saw nothing wrong. So I then picked up the car and saw that the oil was leaking from the oil filter. Removed it and saw two damn seals on it. Effen dumb $hit, forgot to remove the seal. The motor had lost about 3.5 quarts. Didn't go back and talk $hit b/c the guy is my friends, friend. I was lucky that my motor didnt blow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coreyhayman »</TD></TR><TR><TD CLASS="quote">was cruising home last night at 1am doing 110km/h in 5th when all of a sudden boom, car shuts off and the cabin fills with smoke, i pull over to theside of the road and me and my girlfriend get out and theres a huge puddle of oil under my car. I get underneath and look and theres a huge hole in the bottom of my oil pan, i can feel something in the pan when i stick my finger in there moving around. the car wont start now either, now, i also checked the timing belt and its gone. I had the car in the shop 2 weeks ago getting a brand new timing belt and water pump installed and its snapped. This shop better be replacing my motor, my question is if the belt snapped would it send something flying through my pan to put the huge hole in it? I cant believe this happend the car was just in the shop 2 weeks ago being gone over, ridiculous and it only had 170,000k's</TD></TR></TABLE>
If you still have the reciepts, i dont see why you couldn't get a new motor in small Claims courts. I NEVER Take my car to a shop just for that reason. All my work is done by ME, swaps, oil changes, timing belts, anything. Anyways i hope you get it taken care of.
-Rob
well the other thing is, she took the car back a second time to them and complained cause it came back with the cel on, and ran shittier then when it first went there. Also they were supposed to check her air filter cause she told them to and they said they did, i took the bumper off cause the cars slammed to get it onto the tow truck and the ******* air filter was clogged and rusted shut pretty much (c.a.i)
SpecialRequest
10
Apr 14, 2015 02:45 PM
Jonathan_ED3
Apr 8, 2003 05:23 AM
