b16 distributor
ok sorry , i know lot of this have been wiriten abt this, but plz some1 explain, 1st iam writing from Fiji. ok i have a 1989 crx si . iam putin a 89 civic b16a engine,
iam using the old wriing fron zc , just runin my 2 wire (knock n solenoid i was told only run these 2 wire as my b16 ecu have been reprogramed)
ok the wory part is distributor iam confuz hia, the wirte up's say join the wire , i can only c 1 plug with 7 wrie (thats the round 1) , which plug or wire i connect to this ?where is the grey plug?
thanks
Modified by fiji_crx at 12:42 PM 9/17/2006
thanks
is the grey plug attached to the harness because if it is that is the obd1 harness and you need to either get a new harness or wire up the one you have you can search the net for a wire diagram
88crxdxfastwhip
May 30, 2008 10:31 PM
BukakkEK9
Oct 15, 2006 01:01 PM
