fuel injectors
Old Sep 16, 2006 | 10:26 PM
nodnarb660's Avatar
Default fuel injectors
Are 395cc injectors to big for the following setup?
1996 Acura integra GSR B18c1 engine
Cp pistons 9.8:1 cr stock bore
eagle rods
golden eagle hd sleeves with o ringed cylinders
cylinder head is ported and polished by port flow design
3 angle valve job with stainless steel valves, titanium valve springs and retainers
stock cams
arp head studs
edelbrock victor x intake
edelbrock victor x throttle body 65mm
msd sci igniton
msd pro billet distributor
unorthodox pulley kit
venom cam gears
aem fuel rail, fuel pressure regulator, fuel filter
255 walbro fuel pump
act extreme duty pressure plate with street disc
act lightened flywheel
quaife lsd.
Drive Shaft Shop stage 3 axles
Any information would be greatly appreciated.
Thank you,
Brandon
Old Sep 16, 2006 | 11:33 PM
AznBlueBoy's Avatar
Default Re: fuel injectors (nodnarb660)
9.8CR on all motor? ehhhhhh....
Old Sep 17, 2006 | 06:07 AM
nodnarb660's Avatar
Default Re: fuel injectors (AznBlueBoy)
Yeah the motor is 9.8 i just put this in the all motor section because i don't have a turbo yet .... i just want to know if those injectors are to big on that setup for now.
Old Sep 17, 2006 | 07:45 AM
tealegg's Avatar
stock ecu = yes. uberdata chrome hondata ect. = no.
brad92
Aug 25, 2011 03:36 PM
hany
10
Jan 14, 2007 04:03 PM
inzane
Nov 21, 2005 05:07 AM
GForceInteg
May 21, 2004 05:34 PM
N.O.S JUNKY
Aug 25, 2003 02:40 PM
