******** HELP!!!! Trouble with my B16 CRX ***********
Old Apr 30, 2002 | 05:22 AM
shiithook's Avatar
Default ******** HELP!!!! Trouble with my B16 CRX ***********
When I finished the swap and first started the motor it ran great. It started running worse. I checked and double checked all of the vacuum connections, then it would only rev to 4000 then it would backfire and sputter never getting over 4000 RPM. Then I replaced a broken TPS. Now it wont even start. It also only sometimes throws codes. The ECU light just stays on constantly. Any help would be greatly appericated.
Old Apr 30, 2002 | 05:32 AM
Trinity's Avatar
Default Re: ******** HELP!!!! Trouble with my B16 CRX *********** (shiithook)
the ecu light stays on, like it doesn't blink at all?
the rev problem sounds like fuel but i don't know
badCRX's Avatar
New User
Do you remember what those other codes are? On the older B16's, sometimes they have distributor problems where a screw is coming loose, rotor or ignitor needs to be replaced.
Did you check your TPS voltage once you installed a new one?
Old Apr 30, 2002 | 06:29 AM
june's Avatar
I had that same problem it was my second oxygen sensor was not wired correctly to the ecu. It was like it was load with gas and spluttering like crazy and it wouldn't past like 4000rpm's. Recheck the wiring from the ecu to the o2 sensor. Hope this helps.
Old Apr 30, 2002 | 08:41 AM
mafioso102's Avatar
New User
Default Re: ******** HELP!!!! Trouble with my B16 CRX *********** (civicefhatchback)
sounds like your car is in safe mode. It sounds like perhaps an injector wiring problem
Old Apr 30, 2002 | 11:34 AM
shiithook's Avatar
Default Re: ******** HELP!!!! Trouble with my B16 CRX *********** (Trinity)
It stays on, I was wondering if that was a code 0. Like an ECU problem. But sometimes it will throw a code 7 or a code 6.
Old Apr 30, 2002 | 11:41 AM
HybridRexy's Avatar
Are you running one or two o2 sensors??
Old Apr 30, 2002 | 11:43 AM
shiithook's Avatar
Default Re: ******** HELP!!!! Trouble with my B16 CRX *********** (HybridRexy)
2 in the stock manifold. I got the Hasport Si to SiR harness.
Old Apr 30, 2002 | 11:44 AM
chhuong's Avatar
If the ecu light stays on it means the ecu is ****!! And even though you have a bad ecu sometimes it will detect other things that are wrong and throw those codes too. But i say try another ecu and see if it will help.
Old Apr 30, 2002 | 11:47 AM
HybridRexy's Avatar
Default Re: ******** HELP!!!! Trouble with my B16 CRX *********** (chhuong)
im using my stock harness which is rewired for a b18c and I only have one o2 sensor on the header
Old Apr 30, 2002 | 11:52 AM
shiithook's Avatar
I just talked to Steve from Hondamotorsonline (straight up good guy) and I am sending my ECU back to get it replaced. What should I check in regards to the fuel problem?
Old Apr 30, 2002 | 12:40 PM
shiithook's Avatar
I also dont have a Dashpot Diaphram. Is this a crucial part?
Old Apr 30, 2002 | 02:07 PM
june's Avatar
It's the same problem I was having. Recheck the wiring from the ecu to the o2 sensor.
Old Apr 30, 2002 | 06:43 PM
shiithook's Avatar
I checked the connections to the ECU and the second O2 sensor and it wasnt pinned right, I fixed it but it still wont start.
ef8-dc2619
Jan 31, 2007 04:29 PM
h22egAZ
Nov 1, 2005 10:48 PM
crx_soldier
May 2, 2005 01:16 PM
jdmazm
Apr 24, 2005 04:35 PM
crxsk8er957
Dec 8, 2004 10:53 AM
