How to adjust the throttle cable??
Old Apr 30, 2002 | 04:25 AM
hooptie157's Avatar
Default How to adjust the throttle cable??
my throttle is feeling alittle loose and I want to adjust it. How do you make that adjustment?
Old Apr 30, 2002 | 04:53 AM
Flux's Avatar
Default Re: How to adjust the throttle cable?? (hooptie157)
You buy a Helms manual....
www.helminc.com
Old Apr 30, 2002 | 04:56 AM
hooptie157's Avatar
Default Re: How to adjust the throttle cable?? (Flux)
www.helminc.com
Yeah I was expect a remark like that but does anyone Actually know how and want to share with me??? Or is it too hard to do on your own
Old Apr 30, 2002 | 05:08 AM
Flux's Avatar
Sorry, I wasn't trying to be sarcastic or rude - I'm at work and don't have my manual or I would tell you. From memory (disclaimer): find the cable- there are 2 nuts. One is a locking nut and the other tightens/loosens the cable depending on which way you turn it.
Be sure not to over tighten.
Old Apr 30, 2002 | 05:29 AM
hooptie157's Avatar
thanks flux I'm going out just to spec it out right now, and I didn't think you were being sarcasitic it was a reasonable answer
Old Apr 30, 2002 | 05:52 AM
pyromaster's Avatar
OK here goes-
1 you loosen the two nuts.
2 if you're facing the car, pull the cable gently toward the driver side until you hear the idle change. then loosen it until the rpms drop back.
3 once you get the cable where you want it- tighten the nuts back.
-jeff
AtoZ
Aug 13, 2010 10:16 AM
KimChiKid
Oct 8, 2006 07:26 PM
VWkila
Jan 13, 2005 06:53 PM
rockwilda
Aug 25, 2002 08:32 PM
