!!!!!!!!!!!!!!!! LEAKING IN TRUNK HOW TO FIX !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 16, 2006 | 03:46 PM
4gencivicef9's Avatar
Default !!!!!!!!!!!!!!!! LEAKING IN TRUNK HOW TO FIX !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I have a hatch that is leaking in the trunk and both sides.. I cannot figure out how to stop it,,, I know it is coming from back behind the plastic panels, I do not know how to fix anyone>>>?
Old Sep 16, 2006 | 03:58 PM
CRX MASE's Avatar
Default Re: !!!!!!!!!!!!!!!! LEAKING IN TRUNK HOW TO FIX !!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (4gencivicef9)
check your tailights gaskets
Old Sep 16, 2006 | 04:30 PM
MRN1120's Avatar
Default Re: !!!!!!!!!!!!!!!! LEAKING IN TRUNK HOW TO FIX !!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (CRX MASE)
and the drain tubes for the sunroof
Old Sep 16, 2006 | 08:46 PM
ITR640's Avatar
I had the same problem in my CRX, changed the tail light gaskets, problem solved
Old Sep 16, 2006 | 10:16 PM
714CA-EF's Avatar
Default Re: (ITR640)
how do you drain the sunroof? thanks
Old Sep 16, 2006 | 11:59 PM
SECURITY's Avatar
Default Re: (714CA-EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 714CA-EF &raquo;</TD></TR><TR><TD CLASS="quote">how do you drain the sunroof? thanks</TD></TR></TABLE>
If you drop the headliner, you will see a yellow hose at each corner of the sunroof pan. Blow some compressed air through them to free up any build up
Oh n Btw..
!!!!!!!!!!!!!!!!!!ANNOYING THREAD TITLE!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 17, 2006 | 08:47 AM
they kinda of old, where do I get new ones.....
I dont have a sunroof, I have a dx..
Old Sep 17, 2006 | 08:48 AM
Default Re: (SECURITY)
lol Thanks I did that cause it is annoying problem ....
Old Sep 17, 2006 | 10:44 AM
tolnep's Avatar
Default Re: (4gencivicef9)
had same problem in 91 crx. the rain gunnels in the roof on both sides, underneath leak after a certain number of years. i removed the long rubber/metal things, bought an applicator gun and some special binary sealing compoiund and put that stuff on from the windshield back to the trunk lid. replaced the strip things.. then replaced the trunk/hatch rubber seal and finally had to replace the gaskets for the rear taillights. before that my tire well was filling with water when it rained. began to notice when the car would fog up on hot days.
Old Sep 19, 2006 | 06:56 AM
Default Re: (tolnep)
yup thats my problem I am going to try to get r done lol
Where did you get the strips, Honda
What joint compound did u use
Old Sep 19, 2006 | 07:11 AM
'90crxSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR640 &raquo;</TD></TR><TR><TD CLASS="quote">I had the same problem in my CRX, changed the tail light gaskets, problem solved</TD></TR></TABLE>
Yes, where did you locate the tail light gaskets? I've been searching, and have not found anything, except making your own...k
Old Sep 19, 2006 | 07:35 AM
Default Re: ('90crxSI)
did you try honda?
Old Sep 19, 2006 | 07:37 AM
I was thinking what if you doubled the gaskets, like got another set from the junkyard and sealed them together and made one of them covered in water proof sealent...
Old Sep 19, 2006 | 07:57 AM
'90crxSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4gencivicef9 &raquo;</TD></TR><TR><TD CLASS="quote">did you try honda?</TD></TR></TABLE>
as a last resort...I'll try Honda, but they tend to be uber expensive on most things anyhow! I wanted to see if anyone found them somewhere else at a decent price...
Not sure if making them like that would work? It may...but good luck finding a crx in a junyard.....and with tail lights! (at least they dont exist down here...they get crushed almost immedieatly upon arrival....About 20 junkyards are supposed to call me when they get the next one in, but I highly doubt they'll remember)
Old Sep 19, 2006 | 08:28 AM
I have to crxs in the junkyard up here I could ****** a pair o fgaskets for you, I have a hatch though much easier...to find let me know,,
Old Sep 19, 2006 | 11:59 AM
1 Fly SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tolnep &raquo;</TD></TR><TR><TD CLASS="quote">had same problem in 91 crx. the rain gunnels in the roof on both sides, underneath leak after a certain number of years. i removed the long rubber/metal things, bought an applicator gun and some special binary sealing compoiund and put that stuff on from the windshield back to the trunk lid. replaced the strip things.. then replaced the trunk/hatch rubber seal and finally had to replace the gaskets for the rear taillights. before that my tire well was filling with water when it rained. began to notice when the car would fog up on hot days.</TD></TR></TABLE>
There called Drip guards
Old Sep 19, 2006 | 12:36 PM
Default Re: (1 Fly SI)
thanks for the name I was going to call honda and ask them for the part name for I could order them...
Old Sep 19, 2006 | 04:09 PM
raffaelli's Avatar
I had the same problem in my 91 si. Just drilled a hold under the spare and forgot about it!!!! lol
Old Sep 21, 2006 | 08:58 AM
Default Re: (raffaelli)
thats good but then water is going to rust out your gas tank
Old Sep 21, 2006 | 09:00 AM
ef8powr91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX MASE &raquo;</TD></TR><TR><TD CLASS="quote">check your tailights gaskets
yup
CARflyGUY
Nov 22, 2006 08:10 AM
90AccordTx
Jun 23, 2005 06:43 PM
95GS-R
Dec 28, 2003 03:11 PM
raene
Sep 5, 2003 02:31 PM
paeaknoy
Jun 26, 2003 04:27 AM
