diy stroker kit yes i have searched!!
Old Sep 16, 2006 | 03:35 PM
jdm ek9 101's Avatar
Default diy stroker kit yes i have searched!!
im looking at this set up and just have a few ?'s
block-b16b
crank-b18c
head-b16b
pistons-p30 b16a
con rods-b18c
2 layer haed gasket
will does p30's be strong enough for this build are will i go for aftermarket ones?
i will be looking for 11.4/11.5 comp from this build do you thinks thats right?
and will the pins off the p30 be ok for b18c con rods?
and whats the ctr stroke?i know the itr is 87.2mm
Modified by jdm ek9 101 at 4:56 PM 9/16/2006
Old Sep 16, 2006 | 06:44 PM
Phil M's Avatar
Default Re: diy stroker kit yes i have searched!! (jdm ek9 101)
It will be fine as long as you dont rev that **** to the moon. Get new arp rod bolts.
Old Sep 16, 2006 | 06:46 PM
loudassVTEC's Avatar
Default Re: diy stroker kit yes i have searched!! (theyoungone)
to the moon you mean 9000+?? or will it be fine to revv that high?
Old Sep 17, 2006 | 01:06 AM
Default Re: diy stroker kit yes i have searched!! (loudassVTEC)
im using bc3's so there only good to about 8,500rpm so i probley wont be going past that.
Old Sep 17, 2006 | 07:10 AM
Phil M's Avatar
That should be fine.
adamquik
Aug 16, 2007 05:01 PM
ActiveAero
Jan 7, 2004 09:19 PM
Drag_On
Jun 26, 2003 10:56 AM
InevitableRace
Feb 23, 2003 10:08 PM
StinkyTofu
Jan 11, 2003 04:33 PM
